I have done a lot of Mods
I hope you find some interesting (may be)
More and larger pictures:
http://arianeoveleiro.blogspot.com/2009/05/trailer.html
Jose
No , it is a Macgergor 1997 trailer.bastonjock wrote:was your trailer made by west mercia?
Yes it works like that. it is automatic.USAF M26X sailor wrote:The 5th pin is sometimes use as the connection between you tow vehicle's back up lights and your trailer brake lock out
Not sure what a "tongle" is... are you referring to the "tongue" (the long part that goes over the ball on the hitch)?J.Teixeira wrote:Is TONGLE the correct name ?
We in the US generally refer to that as the "Trailer Jack".J.Teixeira wrote:Is LIFT the correct name for the vertical "winch" ??? Is it JACK?
Yep!J.Teixeira wrote:Is WINCH the correct name for the "winch" that pulls the boat bi the bow ???
OK... I'll give it a go....J.Teixeira wrote:The text that needs a checking is:
http://www.macgregorsailors.com/modt/in ... ?view=1174
Thanks
Jose
Not sure what you meant by that last line, Jose. Did you mean that the trailer's new jack allows you to raise the trailer so that the boat can be hauled aboard the trailer from a position in your back garden?Trailer Tongue:
To install new brakes I had to replace the trailer's tongue. This one has an electric servo for auto reverse and a new powerful trailer jack.
Tire:
Replacing the small reinforcement bar with a larger one provided a perfect place for mounting the spare tire.
Winch:
The winch support was moved down and inverted. A larger and more powerful new winch was installed. The most interesting feature is that the winch has a 2-speed system and the second speed is so powerful that the Mac "bump" is no longer necessary.
Trailer Jack:
Longer and more powerful jack to use the trailer to lift the boat directly on the garden shipyard
What I am trying to say is that the larger trailer jack, allows me to haul the trailer with the boat.kmclemore wrote: Trailer Jack:
Trailer Jack:
Longer and more powerful jack can be used to lift the boat directly onto a home-made cradle in my back garden and to remove the trailer when bottom maintenance is required.
