ballast arrangement in the Macs. We pull ours with a big Chevy Suburban with a 454 in it.
We tow our 5,000lb RV around with no trouble. I don't think I need to be concerned about the weight.
The trailer has dual axles. We seldom bother dumping the water ballast in the summer when
we park it in the yard beside the lake. (Yes, we always check ballast is full before leaving dock)
Seemingly the tires and suspension handle the extra lbs just fine.
The reason I'm curious about permanent ballast is, I think if the keel had the same
mass of (say) lead in it, as the weight of the water we carry, the boat would be "stiffer" and
not heel over so dramatically right away. I think this would let us carry more sail and sail
flatter on the water. It's probably a moron idea but I'd enjoy not being knocked over
25 degrees every time an errant gust comes along.
I saw where, on La Perla Noir, they increased the permanent ballast to some degree.
Jokingly, I am more inclined towards filling the whole thing with sand or birdshot or cement.
Any one have any comments or experience or ideas about this? Or maybe the topic isn't worth the bandwidth...
But thank you,
Laurie
