Our Wallas 1300 is mounted on the Port side of the boat above the Galley--aft of the sink, just below the back side window. There is a 1 gal container of mineral spirits secured under the galley sink in a sealed container with the fittings to the stove coming up through the Galley top at the back and feeding the unit. The exhaust/intake hose goes straight up and exits to the port and forward of the winch. It requires a 2 inch hole. The stainless exhaust fitting that sticks out of the boat can be sealed by pressing down and twisting and one has to remember to open it before using the heater. It is round and smooth and doesn't foul lines. It never leaks water into the cabin. It gets hot to the touch and when on the hard and covered, I fold back the cover to use the heater to work on the boat.
Mounted in this location, it is convenient to turn on and off-you don't have to pay for the remote switch, the exhaust is short and direct, and there is no duct work to install. Duct work for heated cabin air is limited to 3 feet if you do an under cabinet install. That makes this the cheapest and easiest install. That said, I am considering moving it to under the cabinet. If you put this in Google: c-brats install "Wallas 1300" you can see how one guy installed in a Cape Dory. I would, however. put exhaust exit higher on the boat than he did. My exhaust is all metal. You can buy side exhaust fittings instead of top if you want to exhaust out side.
The heat is about the amount of heat you would get from a 1500W electric heater but the fan propels the heat better. There is no extra moisture put into the boat and it uses no boat oxygen and no CO or CO2 increase since it brings in outside air through the outer tube. The amount of fuel use is tiny. There is no odor in the cabin, but slight mineral spirits odor outside when burning--very slight.
Ned
