Macgregor 26X Outsails a Catalina 27..
John McDonough
Sunday around noon the NOAA weather forecast was calling for 25-30mph south winds on Lake Erie.
NOAA forecast was calling for Gale warning to begin at 4PM with Gusts over 50 MPH. The Tail end of IKE still going
With High winds, and no crew, I didnt want to hoist the mainsail..
About 12.30 PM, I went out in the bay, SOLO, and just unfurled the Genoa about 80%. The 26X to windward took off and I slowly started catching up to the boat about 1 mile ahead of me. It was a Catalina 27 with full Main Sail only. I passed the 27 and we started racing, he was able to tack closer to windward, but I was still gaining. as We reached the end of the bay and headed back downwind I just walked away from the 27. The Gusts kept knocking me over and I went back to the dock before it got too bad.
It was a great feeling to pass other boats, usually they all pass us.. Maybe the 27 was a novice, or maybe being late in Summer he had a fouled bottom, and I had just scrubbed my bottom before leaving the dock that morning.
- Love MACs
Re: Macgregor 26X Outsails a Catalina 27..
Hey John..give a little credit to the Captain of that X.
Maybe ure just a better sailor
Allan
Allan
- beene
..Mom always said to do that...... never know when you'll end up in the hospital....I had just scrubbed my bottom before leaving the dock that morning.
LOL
John McDonough
I just scrubbed my bottom.
I take a shower once a month, weather I need it or not..
About the boat bottom...I have never applied anti fouling paint to my 26X, just Marine wax with teflon. Keeping boat in a marina slime builds up. Years of sailing, I am 100% convined that not cleaning the bottom slows down sailing performance. I try to anchor in shallow water and walk around the boat with long brush and clean off all the slime. Mask and spoone for the centerboard. If Its bad weather I clean the bottom by laying down on the dock and use a long handle brush to clean. If i dont clean off the slime for 3 weeks, it is now imposssible to get it clean in the water. Get the trailor, pull it out of the water, scrub brush and some soap.
Walking around the Marina, I notice quite a few boats sit there for weeks without use and even with anti fouling paint, they have a green coat of slime cemented to the hull..
waternwaves
John....
those winds are the best!!!!!!
your're already surfing when the other boat is still trying to lift ....
10-25 steady is perfect.....
it is just too dang rare.....
- NiceAft
Yeah John! Give yourself more credit. Show some Pennsylvania pride. You out sailed him
Give yourself a LOT more credit !
Code: Select all
Portsmouth Yardstick
OFFSHORE CLASSES NAPY D-PN
************************* CODE
Precision 18 PRS18 (101.0)
Capri 18 (Catalina, WK) CAP18 100.7
MacGregor 26X SK MCG26X 100.0
Hunter 18.5 (WK) HTR185 99.2
Catalina 22 (FK, No Spi) CAT22F 97.1
Catalina 22 (SK/WK, No/Spi) CAT22 96.3
MacGregor 26M DB MCG26M [96.0]
MacGregor 25 MCG25 96.0
MacGregor 25 (MH Rig) MCG25M 95.4
Catalina 25 WK,Tall Mast, Spi CAT25LH 95.1
Catalina 22 (SK/WK, w/Spi) CAT222 94.7
Catalina 25 FK/SK/WK, Spi CAT25 93.9
Catalina 250 spi CAT250 95.6
MacGregor 26 SK (MCG26W) MCG26S 94.3
MacGregor 26 DB (MCG26) MCG26D 92.6
Hunter 260 HTR260 91.2
Catalina 27 TM, Fix Prop, Spi CAT27H2 90.8
Capri 22 (Cat., FK/SK/WK) CAP22 90.8
Catalina 25 FK/SK, TM, Spi CAT25H 90.1
Capri 22 (Cat., Tall Rig) CAP22H 88.9
Catalina 27 & 270 FK/WK, Sp CAT27 87.4
Catalina 27 Tall Mast, Spi CAT27H 86.4
Parentheses ( ) around numbers indicate between 5 and 15 data points
Brackets [ ] around numbers indicate calculated number or fewer than 5 data points
Re: Macgregor 26X Outsailing a Hunter Power Sailer
Well now to see if the 26X Outsails a Hunter 27 Edge. This is the power sailer introduced by Hunter last month. She caries a 75 HP motor, an interior like the regular Hunter 27s, and a mainsail like an Ocean 70. I understand they run about 65,000. I wonder if the Hunter main will fit a 26x - Huzzah, looks like another year of spirited power sailer discussion. When does Catalina get the message. The Future of Yacht Design is now.
Frank Mighetto
1999 Mac26x
Frank Mighetto
1999 Mac26x
