A question of design for the 26X......
- WD
Re: A question of design for the 26X......
Hi Hart, sorry i should have been a little more explicit. "My travels" meant virtual travels on the net, so what i was saying is i thought i've seen pictures somewhere of a yacht with the name Wind Song.
Cheers, Bill
Cheers, Bill
- Hamin' X
There are several mods for the vent. A search of the Mac Mods section, using proper terms will work. ~Rich2BonC wrote:. . . By the way as I´m most of the time single handed it´s quite uncomfortable to close the valve and then jumping to the v-berth to close the airvent. I´m still looking for a mod to get rid of this plug. I´ve seen some at the mg-pages however they were all to specific to use US-offtheshelf products.
ModsEdit by ~fc:
Also try searching the Forum for detailed discussions. Use the phrase passive ballast vent.
Use 'Advanced Search' to search on "Topic Titles only" and find one comprehensive thread.
Then search for "Post subjects and message text" to find a dozen other threads.
Generic products can accomplish this mod.
If you tighten those two bolts that secure the ladder at the base of the companionway, it will stay up all by itself...We have a line attached long enough to loop over the starboard
My 2001 X has the ladder to the floor and the air vent in a cup under the aft end of the v-berth. I recall reading that configuration also locates the C/G of the filled ballast tank further forward to compensate for the weight added on the aft end of the boat by the newer 4 stroke motors, which are heavier than the early 50 hp 2 str Tohatsu motors used onthe first years of the X....to my mind a more significant improvement than the ladder configuration change. Ron
SailDog
- Location: New Hampshire ....... "Come Monday" 2001 26X ....... Merc 50 Bigfoot
You know you're right! Tightened the bolts, and the ladder stays put!Kelly Hanson East wrote:If you tighten those two bolts that secure the ladder at the base of the companionway, it will stay up all by itself...We have a line attached long enough to loop over the starboard
-Pat
John McDonough
I owned a 1997
which I bought used in 1998. less than 4 hours in the water. I thought the water ballast system was a pain in the butt. I had owned a Mac 26D for 10 years and was not happy with the new model mac
I went to the Cleveland boat show in Feb 2000 with the intentions of buying a new sailboat or try buying my old 26D back. While there I noticed that Macgregor had improved the
. Roger Macgregor improved all the things I though was wrong with the boat. I ended up buying a 2000.It still doesnt sail as well as a traditional sailboat, but once your spoiled by a 50 hp motor itts hard to go back.
if anyone is in the market for a used 26x, avoid the first 3 years models, with that stupid valve system under the step.
I understand the inspiration for mods.it´s not a matter of time or hurry but I´d like to avoid being forced in the cabin and waiting for the waterlevel to raise
Also, while I usually rig on the water, I let the ballast fill up while stepping the mast.
- 2BonC
Thank You Hamin X for Your hints to allow me more specific searches, will use them. I must say
sailors must be very nice people, they never let You stay in the rain, thanks to all
Rainer
Rainer
