18" Destroyer Wheel
- tangentair
Dave X2000 Jac
I replaced the original with a 20" wheel. It's great. When heeled over, I can sit in a side seat and not have to uncomfortably stretch my arm when I handle the wheel.
I didn't find removing the old wheel nearly as tricky as re-attaching the far end of the steering mechanism through the hole, sealing it properly, and replacing the rubber "boot".
- c130king
When I installed my new Teleflex R&P steering system last Spring the instructions specifically mentioned that this system was for max steering wheel size of 16".
Any of you smart engineering types think an 18" will be problem? Is the issue too much "torque" on the R&P?
I am considering sending more of my money to KH Marine.
- RickJ
- Sailboat: MacGregor 19
The "max diameter" warning on the Teleflex systems seems pretty arbitrary to me.
Obviously there is a max. torque on the steering shaft that the system is designed for, but translating that into a wheel diameter means making big assumptions about how much force a person is going to apply at the rim of the wheel. I'm sure a gorilla could apply more torque to a 12" wheel than a dainty lass would to an 20" (not trying to be either sexist or apeist here
