What is the sequence for installation for installing a stock prop onto the Suzuki DF50.
Can someone please confirm it is as follows to install a prop onto a bare shaft:
Prop
Large spacer (which way down?)
SS washer
Castle Nut
Cotter Pin
Installation sequence for propeller on Suzuki DF50
- live2shift
Make SURE there's a large splined thrust washer on the splined shaft before you install the prop. Hopefully, this drawing of the DF50 will help:
http://store.brownspoint.com/df50/fig047-05001F.asp
Grease the splined shaft the thrust washers slide on or they can get stuck on it.
Moe
Moe
