question about sail covers
MARK PASSMORE
Post by MARK PASSMORE »
I would like to purchase a mainsail cover and a Sail Sock for my Genoa on my 07 :macm: . Any suggestions. Is Kelly Hanson the way to go and will it be the best Quality. Do I want one that zips under the boom or the kind that has the hooks that twist or snaps? :? Thanks in advance for the help. :)
Scott
Post by Scott »
Mark zippers -R- cool but anything with a zipper made of sunbrella inevitably suffers from the zipper jambing on the frayed sunbrella material.
Ask most mac owners about their Bimini covers.
I would go with the grommet and twist lock do-hickeys
Ivan Awfulitch
Post by Ivan Awfulitch »
Not sure what you're asking. For the Genoa, mine came with a cover sewn on. The less expensive route would be a sleeve type. Softopper makes a nice one that you hoist with the halyard and zip as you go.
http://www.softopper.com/jib_genoa_cover.html
They also make a very nice mainsail cover that I purchased for this year.
http://www.softopper.com/sail_cover.html
My main cover has twist (snaps) under the boom. It says "MacGregor" on the side so it must be a factory cover. I kind of like that because it can breathe and water can't get trapped in there. Keeps rain off, but most important keeps sun off.
I have a zipper sock for the roller furler. My last boat had sunbrella material sewn into the sail that wrapped around. I'm told these smaller sails don't work well that way because the sunbrella is too stiff. So I've got a sock.
I've only had my :macm: out twice, but I don't like the sock. So far, it takes 2 people. One to zipper it and another to pull the halyard. Perhaps I'll get better at it, but I'm clumsy hoisting it up.
Still, Dacron and sunlight are not friends, so cover them up.
James V
Post by James V »
Try here -
http://shop.macgregorowners.com/home3.htm?fno=80
I bought mine from them and have been happy. I also bought a pedistal cover. Nice addition to protect electronics.
BWY also has some.
Wind Chime
Post by Wind Chime »
Ours came from Blue Water Yachts.
The mainsail cover has the twist snaps both on the bottom and up the mast, with a tie at the top of the mast section that snugs everything tight so very little rain gets onto the head of the sail. It works excellent.
Our headsil cover on the other hand, is a serious pain in the aft :). It has three seperate short zippers for some reason??. If we were to buy a new one, it would have only two zippers. One long one from the top to where the sheets tie to the clew, then a short space between the two zippers (12 inches for the sheets to go through) then the shorter zipper to go down to the deck.
Darry
MARK PASSMORE
Thanks guys I really appreciate the advise. I will probably order something this week. The admiral says it can be my Fathers Day gift.
My mainsail cover has the twist locks on the boom, and a zipper up the mast :) Both techniques work well. In fact, I like that combination.
While the Admiral powers Nice Aft into the wind, to put on the cover, I zip the mainsail cover onto the mast. While the part that covers the boom is acting like Superman's cape, I close each twist lock starting at the one close to the mast, and then work my way aft. I do the reverse when taking off the cover. It works quite well. By the way, the sail cover is made of black Sunbrella.
daydreamerbob
Location: 2008 26M, Yamaha T60, Lake Allatoona - Acworth, GA, Very Much Faster Blue Hull - No Scratches
Post by daydreamerbob »
Mark:
My main sail cover has the twisty grommet thingy ma bobs on the boom and a zipper and tie on the mast. my genny has a furler cover. i like what i have.
c130king
Post by c130king »
Main: Zipper on the front by the mast, and snaps on the bottom.
Genoa on Furler: One very long zipper. Works great. Can do it singlehanded with no problem. But must make sure to get fairly tight wrap when furling in the sail. Otherwise the middle part of the furled sail is a little "fat" and it gets difficult to get the sock to go over it.
Also, if you go with the sock I think you need to be careful how the sock halyard is rigged. They seem to have a tendancy to wrap around the Genoa when furling and unfurling. My sock halyard block is attached so that it sticks out a little bit forward of the the furler. And then I attach the halyard to my puplit with a snap shackle. I pull it tight to keep it away from the sail. And it kinda/sorta acts like a safety line in case my forestay/furler lets go...or at least I hope it will... :?
r.fairman
Post by r.fairman »
Try comboat on ebay Good Price Good Quality Delivered to Turkey on time
live2shift
Post by live2shift »
I bought a softopper sail cover on ebay for around $150. They also sell them on their website. Nice heavy quality sunbrella and fits my M like a glove with heavy zipper in front, heavy straps underneath. Extra roomy also. Nice people, and a very nice product
Paul S
Post by Paul S »
I had one custom made by a local sailmaker (Harding Sails), it blows away all the sail covers I have seen in quality, fit and finish.. BUT it also was about twice the price of the sail covers I have seen. They might still have the pattern in stock from when they did mine, but there are probably more cost effective solutions out there.
parrothead
Post by parrothead »
My mainsail cover has the twist locks on the boom, and a zipper up the mast. Both techniques work well. In fact, I like that combination.
Same here, except ours also has a flap that snaps over the zipper in front of the mast :) It was supplied by our dealer, made from royal blue Sunbrella by http://www.sailorstailor.com/
They also made our snap-on jib sock, which we now only use for trailering and winter storage [too much windage in the slip].
MARK PASSMORE
I finally ordered the Mainsail cover and the Sail Sock from Kelly Hanson but they e-mailed me back and said it was out of stock. They gave me a refund, so back to square one. :cry: :x :P
