Replacing Rudder Brackets
- Trouts Dream
Has anyone found the need, or a way to replace the original aluminum rudder brackets. I don't think I need to go as far as Mad Mikes brackets but I am curious about the strength of the original brackets. The final straw came when i looked into the IDA rudders and they are only for the stainless steel brackets.
Any input or experience would be welcome.
- Trouts Dream
- hmb-barry
The schematic drawings for the M26 rudder brackets are on the MacGregor26 factory site (macgregor26 dot com) under 'Suppliers Corner', then Hardware Custom.bubba wrote:I was thinking about buying a spair to carry with me. Is there a port and starbord bracket or or they the same? When I get one or a pair I can make detail drawings .................
Barry
- Trouts Dream
IIRC, the change to stainless brackets happened sometime during the '98 or '99 model year. While there are numerous discussions about repairing or replacing the previous aluminum brackets (which had at least two different designs), I don't recall seeing anyone post of a problem with the stainless brackets.
I do recall someone writing about swapping the stainless brackets onto an older boat. IIRC, it was a major effort. The aluminum and stainless brackets are totally different designs, and the rudders differ too.
IF there's no pattern or shelf-stock for the 26X stainless brackets, it's because the design is strong & stable enough that replacements have rarely been needed. I'd phone Factory Bill and ask if he has a drawing for the 26X bracket, then job it out to a local stainless fabricator. Just a SWAG ... plan on spending a bunch of bucks ... $300/pair?
