Rope on aft shroud??
- MadMacX
- Sailboat: Venture 23
Hi All,
I have a small (3/16") rope attached to the aft shroud with a sliding cleat attached. For the life of me, I cannot figure out what that line is for. Up to this point I have left it attached, but I'd like to clean things up and remove it. Does anyone have any idea what the purpose of that line is?
Also, when setting up the mast what do most people do with the furler to keep it from scratching up the windows and gelcoat? I have a cloth bag wrapped around it now, but I wondered what the rest of you were doing.
Thanks, Pat
Thanks, Pat
- Captain Steve
- Trouts Dream
When you refer to the aft shroud, I asume you mean the backstay. If so then the line you are referring to may be for holding the boom up when the main is lowered. I use a single line from the top of the mast to the end of the boom to support the boom. When main is hoisted there is a lot of slack in the line so it doesn't affect sail shape. If you did mean shroud then I'm as baffled as you are.
- Beam's Reach
- Location: North Bay, Ontario, Canada 97X, 50HP Mariner 4 Stroke
- MadMacX
Finally got a hold of the PO and he told me that they used it to hoist a flag of their local sailing club, on the rope in question. Mystery solved.
Regarding the furler, what is the bungie trick, KHE? I tried to bungie it to the pulpit, but it I had it too tight because the bungie was just about at the breaking point before I released it. Please enlighten me because this furler is a major PITA.
Pat
Pat
- MadMacX
OK, KHE, I just tried it again, but this time I used a 60" bungie and tied it off to a bracket on the pulpit. Much better. When I tried it before, I wrapped it around the furler drum a few times which shortened the bungie too much. Now I got it. Thanks for the tip. I'm learning.......slowly, but learning.
Pat
Pat
Retcoastie
Not my idea, came from the board and works like a charm: bungee the furler to the life line, hook it up thru the hole where the pin goes thru. Mast down - the furler drum is just behind the forward stanchion, when you raise the mast it slides back on the lifeline, never touching the deck - it stays at the same distance above.
Hans
Hans
wash mitt
Do you know those wash mitts they have for washing a car? They're usually either fuzzy or made out of fleece fabric, like a big mitten with an elastic wrist. You can often find them at places like Harbor Freight or Ollie's for less than 2 bucks a piece.
If you have a CDI FF2 like many of us, then one of those should fit snuggly over the furler drum with the elastic holding it in place nicely.
I use the mitt on mine even when I'm also using the bungy to hold it out of the way, and I leave it on there when trailering to keep the drum clean and free of squashed bugs and things.
I also find a pair of these mitts real handy for the ends of my mast-raising pole, to help reduce the numbers of dents and dings I tend to put in people and equipment while moving it around!
- Andy
- Andy
- Beam's Reach
