Our keel boat mast was only a little higher, and it had a 12 foot beam and lots of lead in the 4 foot deep fin and I went up half way one time, after that I sent my son up to the top, think metronome, ticking away side to side while you swing and sway, and we had the jib and main halyards running through some pretty substantial blocks to lift us, are you sure you want to trust your weight to those blocks? Like the others suggest, just lower the mast, it is easier to work on it especially when you need a tool or drop one.
csmuaary1.
When you attempt it, would you mind getting your old sheila to take a video.
I can promise you all us blokes down here would love to see it...probably be a scramble to enter it in Funniest Home Videos show too.
Just joking mate....
Personally I would lower the mast.
Phillip
The ADMIRAL was putting on the genoa sock and let the halyard go, zip right up to the top of the mast.
I got lucky with a couple of expantion poles, and a hanger taped to it, took about 15 minutes, I couldnt have lowered and raised the mast/genoa in that time.
My genoa cover rope broke and I am to lazy to pull the mast down, I have it in a slip. Thought I would send my skinny 14 year old up there to feed it through. Looks like I will have to pull her down.
Bill - I would think 15 minutes is about right to lower and raise the mast again? Of course fishing with two boat hooks taped together always looks dignified
