26M and X Speed Test
daydreamerbob
Location: 2008 26M, Yamaha T60, Lake Allatoona - Acworth, GA, Very Much Faster Blue Hull - No Scratches
Post by daydreamerbob »
Hey Guys - here are my stats - what are yours?
2008 26M Yamaha 60 High Thrust (Prop not sure), less that 10 hrs runtime
WOT Full Tank 1 Person - 16.8 mph land speed
WOT Empty Tank 2 Persons - 16.8 mph Land Speed
What's up with that?
Hardcrab
Post by Hardcrab »
How are you measuring your speed?
What RPM's are you seeing?
Any wind, wave or current differences between speed runs?
Are you sure your ballast was full, and conversely, are you sure your ballast was empty?
Lots of variables to consider, but your results do seem strange as reported.
daydreamerbob
no wind, on lake, mast and furler raised, calm water. 5200 ish RPM. measured by my friend lowrance 522 gps.
Post by Kelly Hanson East »
Not that strange depending on weight of crew.
If its a 100# Admiral, 12 gallons of gas weighs 72 pounds and 30 pounds weight wont give a measureable speed difference.
Loefflerh
Post by Loefflerh »
26 M Suzuki 70 and about 10 Hrs runtime as well: Only tested speed briefly, I get 16 mph with 3 persons onboard and full water ballast, 21 without. Tide was no factor, about 10knots of crosswind (from the side) and going in both directions on Gordons river (inner state canal). I am sure I can achieve maybe 1 -2 mph more, but I just wanted to see max Rpm, and as soon as I saw 5400 I went back to normal speed. 5400 told me the prop is properly sized - 13x13.75. I addition my suzuki is installed on wedges from WM, Ithink they are well worth the money.
With my x and a50 Mcury Bigfoot, 16 MPH was the max I ever saw.
Hans
c130king
Post by c130king »
Did you mean empty gas tank or empty ballast tank?
I only have a 40HP Merc (with a powerthruster) and I can get 16.8 with ballast empty and two people.
But I can only get about 14.5 with ballast and 2 people.
tangentair
Post by tangentair »
Reading over back posts when I was breaking in my Merc 50 BF last year, I got the impression that I could expect over 12 but less than 16 under most conditions. Lake conditions, chop, wind and traffic, never let me fully test this but it is my impression that it is a reasonable assumption.
DOH!!!
(gas vs ballast)
:wink:
daydreamerbob
ballast
Bawgy
Post by Bawgy »
I was hoping he had found a way to get 16 knots from his outboard with empty GAS tank ....DANG :( :D :D :D :wink:
Trouts Dream
Post by Trouts Dream »
Sushwap Lake, BC, Canada
Very calm lake
3 Souls on board (My son, his 95 lb girlfriend, myself)
Loaded for cruising (food, clothes boxes of wine, etc)
No Ballast
96 Tohatsu 50 TDLI, with 12.1 x 9 prop
Top speed (sustained) 15.1 KNOTS, 17.4 mph, 27.8 kmph (go metric go)
This was with son and girlfriend straddling the bow. When they were back with me speed dropped to 14.7 knots.
Best speed ever was when Adimral and I were onboard during the same summer and same lake, still outfitted for cruising. She was sleeping in the Vberth and I had to find some internet source fast (client in need) Somehow got up on plane and sustained 17 knots but have been unable to reproduce this again. Smooth bottom (the boats, not mine) with no bottom paint.
Harrison
Post by Harrison »
Loaded boat (food & drinks for 3 days, scuba gear, clothes, gadgets, laptop, tools, etc)
10 gallons of drinking water
Admiral 130lbs
Me 180 lbs
Towing a 78 lbs dinghy
2.5 hp kicker for the dink (30 lbs)
29 gallons of fuel (188 lbs?)
2 type 24 batteries
Mast up
No ballast
60 hp Merc BF spinning a 11 pitch prop
Glass seas
No ballast
WOT = 19.1 mph (statute) (GPS)
And "Yes" it is a White hull! :)
---Harrison
daydreamerbob
i am going to fix the white scuffs and see if that speeds me up
bastonjock
Post by bastonjock »
best speed ibe managed so far,with two adults on board,16.9 knots no ballast,this was with c130king on the bow,speed dropped to 15.5 knots when both were in cockpit.
I did play around with the angle of the engine and managed to squeeze a little more out of her by doing that
forgot to add,Yamaha 50 big foot,prop unknown but the revs get to 5100
RickJ
Sailboat: MacGregor 19
Post by RickJ »
Trouts Dream wrote:She was sleeping in the Vberth ...... got up on plane and sustained 17 knots
Bet she wasn't still sleeping :D
