Total weight of a Trailer+Mac26X+Honda 50HP?
- J.Teixeira
Hi
For trailering in Europe there is maximum weight of 3500 Kg Car+Trailer+Boat+Motor.
What is the total weight of a Trailer+Mac26X+Honda 50HP?
Thank You
Jose
Thank You
Jose
- RickJ
- Sailboat: MacGregor 19
Are you sure about that rule? It certainly doesn't apply in all countries.
26X with engine on trailer is around 1800kg, possibly more if you have lots of gear/fuel/water on board. To tow that safely you should rekon on a tow car with unladen weight >2000kg. My car is about 2200kg, so in total I'm around 4000kg, and in the UK that is definitely not illegal, and as AFAIK is legal on continental Europe too.
Some of the caravan combos I've seen on European roads would also be over 3500kg. There may be a limit of 3500kg for the fully-laden trailer, excluding the tow vehicle.
In the UK there are also different rules if the tow vehicle itself is over 3500kg.
Cheers, Rick
Cheers, Rick
- Beam's Reach
- Location: North Bay, Ontario, Canada 97X, 50HP Mariner 4 Stroke
- J.Teixeira
- bastonjock
there are some slight differences in towing law between the UK and mainland europe,but if you look at your cars vin plate,it will tell you its maximum towing weight.
I tow my mac with a longwheel base mitsubishi shogun/pajero,my towing vehicle is rated at 3.5 tons,it tows a mac
with a yamaha 4 stoke 50hp engine on the back.
you will have no problems getting under the 3.5 ton limit with a fully loaded mac 26x
- RickJ
Ah yes! Sorry, I forgot the driving licence question - I've had my licence long enough I'm not affectedJ.Teixeira wrote:Sory, I did not explain mi self very well.
With a normal driving licence the limit is 3500 Kg.
above that i will need permit B+E
You probably can keep the train weight within 3500 kg, but it will be close. A bare 26X with mast, boom, sails, but no motor and no extra gear on board is almost exactly 1000 kg. The weight of the trailer depends on who made it - in Europe I think it's unlikely to be the US trailer. I have a UK-made double-axle which I think weighs around 600 kg. Don't know details of the Honda, but my Suzuki 55 is about 120 kg, which is fairly heavy for that size engine. So with a tow car weighing less than 1800 kg it would be just within the total.
But that means the car is barely any heavier than the trailer, which does not make for a very stable combination. If you add the extra stuff you'll want to carry, like fuel, various gear - ropes, anchor, fenders, etc. - it all adds up. It would probably be better to load as much of that as possible in the car to improve the weight distribution.
Alternatively take the test to get the B+E category on your licence, then you don't need to worry.
Cheers, Rick
- Beam's Reach
- MSS
- Location: Europe / Sweden 2002X - Honda 50EFI - MACX4868B202
My boat on the trailer is 1680kg and my European style trailer alone is 390kg.
http://macgregorsailors.com/phpBB/viewt ... highlight=
