Motor well not draining.
James V
Post by James V »
I found out why my motor well was not draining. The hose was kinked. Not really enough room under it to make a proper bend. I put in a 90 degree fitting to handle it.
Looks like a something I created.
What ever works :D Maybe you should have posted under "Modifications" :!: :wink: :D
James V
Post by James V »
I did think about that but this is a common post and it would be more read here. Latter if the mod's wish, it can be moved.
tangentair
Post by tangentair »
I was just looking at the same problem last night. Now if I figure out how to get the kid to crawl all the way back there. Neither of us like closed places. I was thinking about making the entire hole size larger at the same time and putting a proper scupper in - 10 bucks seems cheap enough.
R Rae
Post by R Rae »
James,
would you mind crawling back in there once more and take some nice piccys for all to see ??
:D :D :D
Terry
Post by Terry »
Mine plugs all the time, all I do is put the hose nozzle in the transom end and turn it to strong stream and backflush it. All the crud comes flying back out into the engine well and I grab a handfull and scoop it out until the water can flow more freely. No need to crawl under there to replace the hose, that's a bit overkill. :D
Harrison
Post by Harrison »
Terry wrote:Mine plugs all the time, all I do is put the hose nozzle in the transom end and turn it to strong stream and backflush it. All the crud comes flying back out into the engine well and I grab a handfull and scoop it out until the water can flow more freely. No need to crawl under there to replace the hose, that's a bit overkill. :D
That's exactly what I do. Works like a charm.
---Harrison
That makes three of us :!:
TAW02
Just a radical thought ....
Post by TAW02 »
Why not just bypass the drain plumbing and Hog-Out the hole to about 2 inch and elbow a dedicated drain plumb to a new hole-thru fitting? I tellya I am getting fed up with that wimpy half inch hole. A real drain would be able to swallow and pass a mole cricket without a problem.
let there be light ....
UGH :!:
TAW02, couldn't you have used another metaphor :P
Gazmn
Post by Gazmn »
I just fixed a bad clog with mine also. Loews has a plunger that you pump like a bicycle pump. It creates air pressure and can push or pull your clog out. I even tried to snake the clog but couldn't get enough leverage and the elbo joint was to small to access.
Pump worked great. I fished out a 6" piece of rope and some other crap. Now I know why the snake couldn't get it :|
The pump's small and shall stay aboard to pump all the drains as needed...
-Gaz
baldbaby2000
Post by baldbaby2000 »
Mine seems to clog in the section after the sink and motor well tee together. One of us plugs the motor well hole while the other puts a hose on the sink drain and blows (makes for a few good Monica jokes too).
Daniel
Mine also clogs and I use the water-backflush method as well, though I'm careful with the pressure - I don't want to bust the hose loose inside the boat!
What that drain really needs is some sort of domed strainer, so as the drain catches debris, and the water rises in the well, it will still drain.... something like this, but a lot smaller... anyone know of something like this in a small size?
Now you have me wondering Kevin. In the absence of an actual part being out there, could something be jury-rigged? Maybe the following would work? Cut a piece of double stick carpet tape a half inch larger than the drain opening in the well, and apply it squarely on top of the opening. Using a sharp knife, cut out the opening. Place a piece of screen, cut slightly smaller than the tape, on top of the double stick tape. Then place a piece of duct tape ( with a hole cut out of it) over the whole assembly. Might that be something that works until a more permanent, not labor intensive and structural changing solution is had?
tangentair
something like this? or if I knew the size/thread of the item pictured, perhaps something like this Perko scupper could be modified
