Motor Upgrade for Dummies
I have the White Saltwater 90 HP on a 97X. While it's nice, there are truths stranger than fiction. I have not gone over 15kts. With or without ballast. I have bottom paint and a lot of Shtuff. Accept the fact this will never be a speed boat.
- 1- Motor comes with trim, tilt lift.
2- I use 4 6 gal Evenrude portable tanks in the usual place. I believe I'm better balanced with the Ballast in. Otherwise I'm tilted back a hint.
3- You'll get about 10 to 12kts with 4 or 5 people. KEEP THE BALLAST IN.
4-Look to do 8 - 10 kts and be happy. I fill a 6 gal every other outing if I'm out for a couple of hrs.
5- 20" shaft
6- At the very least get backing plates aluminum or SS. There's one I saw that had a bracket on the outside too and it would offset the tilt in a favorable way. I don't have this
7- I'm a lousy, new, sailor. And I can't currently disengage engine from steering. Deal with it. You got more ponies than most sailboats.
8- Haven't tried to manually start. I don't believe you could. Get a Perko and 2 Batts. This motor requires 1000 cranking amp Batteries. Don't fool around with your Batts.
Don't regret it but I'd like to weigh my boat and see what I'm pushing. I expected more ummph from other postings. And I've had my motor checked 3x. It's not the motor... I use a 14x11x3 prop with a 14x9x3 backup. WOT is 4800 RPMS. 17 kts W/ no ballast, Glass conditions no wind, solo. I don't break 5000 rpms no matter what.
Phat Bote
It will be a world of difference from your 25, as it was for me from my former 35. You'll use alot more gas.
Good Luck
