First mod - would like some validation :-)
Posted: Sat Feb 16, 2008 4:26 am
Hi all,
I think I'm about ready for my first set of mods. I plan to add a two line reefing system, a "down haul" for the main, and run all those lines (4) aft.
I was hoping to post links to the hardware I was planning to use, but even though I seem to meet at requirements now I still cannot post links
So I'll just post the product code/name and they can all be found at the mauriprosailing website if you care to look.
As this is my first time, I'd really appreciate if anyone can verify what I am planning is a good way to go and if all of the equipment seems up to the job
What I'm planning is actually very similar to the pictures I've seen via pictures posted by RandyMoon on a thread titled "Main Halyard to Cockpit on 26M" with two exceptions:
1) I will have two single blocks (instead of one) mounted to both the port & starboard base of the mast (4 blocks total). Two for reefing and two for main halyard & downhaul. I was originally planning to just use two double blocks instead of 4 singles but was thinking having a line led up the mast for the main and a line lead more toward the boom for reefing would have a double block trying to be pulled in two separate directions (does that make sense or would two doubles work you think?). The blocks I'm planning to use for all for of these are: "Harken 29 mm Carbo Single / Fixed" (HAR348).
2) Instead of turning the lines aft with deck mounted cheek blocks, I'm thinking I'll turn them aft via a double bullets mounted toward the base of the stanchion on each side. The blocks I'm planning to use for this are: "Harken Bullet Double" (HAR084).
OK, so that is the basic idea I have for getting the lines aft. Just a couple more questions
I assume 5/16 double braid line will work for all of this right? Also, I'm planning to use two of Lewmar triple rope clutches to secure the lines aft ("Lewmar - Superlock D1 Rope Clutch Triple, for lines 5/16 to 3/8 (LEW29101310)"). I was thinking I'm mount these 6 inches to a foot before the line gets to the winch on each side but I realized a problem
At least on a M (don't know about the X), the winches are kind of up on a platform, so I would have to mount the clutches about 3-4 inches lower than the winches. I don't use the winches often, but if I do it seems this could cause a LOT of upward pull on the clutches trying to pull them out of the deck! I think I've read something about wedges to add below the clutches in this case, but I couldn't really understand what was meant. Any info on this?
Thx!!!!!
Tony
Thx!!!!!
Tony
