Need Measurement
Posted: Thu Dec 27, 2007 9:55 pm
by mk_sullivan
I could use the help of someone who has easy access to their 26D on the trailer. I need the measurement from the top of the stantion to the ground while on the trailer. I suspect the 26S is the same in that dimension.
I'm looking at moving my boat home from the slip and the place where I would park it has to sqeeze under an eve and I'm not sure it will fit.
If required, I guess I could remove the stantion, I don't remember how it is attached. Seems like there is just a screw holding it to the base and it should pop out?
Does anyone know where everyone who used to be on the mac Sailnet listserve went? I used to hang out there, but life got in the way and now it seems pretty slow over there.
Thanks!
Mike Sullivan
1988 26D Andiamo
Lopez Lake, CA
boat height
Posted: Sat Dec 29, 2007 3:41 pm
by Paul Brinkley
I measured my 26S and it is 96 inches ground to stanchion top. My trailer is not a Macgregor, but is similar in design and I would expect the height to be nearly the same. Hope this helps. :)
Posted: Sat Dec 29, 2007 8:03 pm
by mk_sullivan
Thanks, that's what I need to know. I think I'm going to have to butter the sides of the boat to get it in, but it should fit.
Thanks again!
--Mike
