Yamah enduro 40 HP outboard alternator with no regulator
Posted: Fri Oct 06, 2006 8:40 am
I have a 1996 mac 26x which I fitted a Yamaha 40 HP Enduro outboard last year. These are rough commercial engines only available in Asia, Africa and parts of Australia. It was cheap (about $2200 US), has 2 cylinders, only one carb, pre-mix @ 50:1, manual lift and no regulator.
I motored from Malaysia, past Langkawi and onto the South tip of Thailand (about 500 NM round trip) and found the battery voltage went off the scale.....upwards of 25v. My sport pilot packed up and although it was replaced under warranty I wondered if the excessive voltage contrubuted to its demise.
The question I have is:- Is it ok to isolate the batteries when they are fully charged to keep them from being damaged by overcharging and keep the voltage on my boat to normal levels or will this wreck the alternator? I know disconnecting the battery while running can wreck a regulator but I don't have one.
Other than that the motor performed perfectly, can be hand started easily and repaired by any outboard mechanic who can use a shifter.
Just one other problem on my trip, the centre ballast valve snapped off in heavy weather and I didn't notice until there was water sloshing around in my boat. Fixed it by going underneath when we got to port by hammering some wooden dowels in to the 2 holes but has this happened to anyone else? I am sealing it off permanently now as I only go to sea with the ballast tank full.
