Page 1 of 3
Channel Island landing news
Posted: Thu Aug 31, 2006 5:36 pm
by Captain Steve
Just back from the storage lot at Channel Islands Harbor....bad news....the lift is broke just in time for the weekend. Hope to have parts late tommorrow .
Lowered the mast and a spreader broke off. The other side was scored and cracked almost thru....I think someone posted some SS replacements????
Posted: Thu Aug 31, 2006 6:08 pm
by Bobby T.-26X #4767
left what?
Posted: Thu Aug 31, 2006 6:38 pm
by richandlori
LIFT...the crane that lifts the boat in the water! That would be BAD!
Posted: Thu Aug 31, 2006 10:38 pm
i understand now.
capn. steve edited the typo for me.
i initially thought something on the left side of capn. steve's Mac was broken.
well, at least it's not something to worry about.
you can always launch at the ramp.
Posted: Fri Sep 01, 2006 8:05 am
by Captain Steve
your right, Bobby...I made the edit. Well with the loss of 2 spreaders, I towed the boat home and will install the GPS today. Did a search and will order a set of reinforced spreaders from boatbimini.com
Posted: Fri Sep 01, 2006 8:47 am
wow, i really mis-understood.
so he broke the lift and your Mac?
what's the deal with "reinforced" spreaders?
i can pick spreaders up at the mac factory from "cash-only" Bill for you. i'll be in "the O.C." next Wednesday.
they're $25 each and include the ends.
shipping would be about $10 (i guess).
let me know...
Posted: Fri Sep 01, 2006 8:53 am
by DLT
Personally, I'd rather a $25 part fail than shift the point of failure ot something else, that may be MUCH more expensive... If it we me, and I could get to the factory, I'd probably just buy 4 and toss the spare two under the rear berth, or wherever...
Posted: Fri Sep 01, 2006 9:02 am
by Captain Steve
Thanks, Bobby. I ordered the spreaders this morning as well as the new dodger. Spreaders 47 bucks...I got to drill the 2 holes.
Posted: Fri Sep 01, 2006 9:51 am
by richandlori
Dodger....interesting....I hope it was less than the one I had made!
Posted: Fri Sep 01, 2006 10:11 am
by Chip Hindes
DLT wrote:Personally, I'd rather a $25 part fail than shift the point of failure ot something else, that may be MUCH more expensive...
Couldn't have said it any better.
Except that, with (it appears) nine years on the original set of spreaders, I'd save the $47 on the spares for under the rear berth, where they're likely to stay for a very long time, and spend it for something more likely to fail.
Posted: Fri Sep 01, 2006 11:05 am
by DLT
Sure you could have! You could have spelled "to" correctly!
Posted: Fri Sep 01, 2006 11:26 am
by Chip Hindes
:D I was just giving you the benefit fo the doubt. :D
Posted: Fri Sep 01, 2006 11:42 am
by DLT
Thanks!
Posted: Fri Sep 01, 2006 5:02 pm
by BK
Steve, a wood dowel from HD slides in perfectly inside the spreader tube for more strength.
PVC also works and may bend better inside the SS spreader tube.
I have had a wood dowel inside of mine for years now.
Make sure to ream the inside of the spreader holder on the mast with emery cloth to remove any burrs or ridges. This is what caused the problem in the first place. It scores the spreader tube and then it snaps.
Posted: Fri Sep 01, 2006 5:10 pm
BK wrote:a wood dowel from HD slides in perfectly inside the spreader tube for more strength.
good idea!
