Raymarine Autopilots
Posted: Wed Jun 14, 2006 1:05 pm
I'm bummed! Found an Autohelm ST5000+ at WM's Oakland Bargain Store, an open box for $999. The compelling benefit I see in using this pilot is that it attaches directly to the steering linkage. In fact, it could be simply clamped directly onto the steering push-pull bar, right on the aft deck. After a bonehead run of the preconfigured cables, it would act directly in lieu of the steering cable.
While plotting my installation tactics, I wrote the following questions to Raymarine's Cust Support guys and just got their final answers - all this relates to the steering linkage for my 26X.
The good news is for 26M'ers ... because your steering linkage is all below deck, you could add the steering redundancy benefits of this heavy-duty sailpilot for just a bit more than a BoatBuck. Last I looked there were a half-dozen of them at the Oakland Bargain Store.
- Sent to Raymarine:
I purchased (from West Marine) a refurbished Autohelm ST5000+, linear drive. It is well-beyond necessary power for my Macgregor 26-foot sailboat (and so, it can easily do the job). My boat's twin rudders, plus an outboard, are connected with stainless tubing and push-pulled by a cable-driven steering wheel. Your horseshoe-style girdle bracket (from your Volvo KAD32 kit) could easily be attached to my cable actuator, but with these several installation questions:
1. can the girdle bracket (and drive unit) be installed on it's side rather than upright? (This provides the best fit, and would also permit the girdle's tilting ability to track with the steering linkage's travel.)
Answer: ==> You are sailing in un chartered waters. I have never seen a Linear drive installed on this boat so I can not advise you. It's going to all be trial and error.
2. can the drive unit be installed on my open aft-deck, subject to rain and occasional waves.
==> The Linear drive is not water proof and can not be exposed to rain water, sea water, or wash down.
3. My steering linkage moves 7 inches from lock to lock, can the drive be adjusted to remain within that range limit?
==> This pilot does have Electronic rudder stops. You set these up in calibration.
4. The owner guide speaks to an "auto-tack" feature, but it's not ever described (not in Chapter 2, or elsewhere)?
==> The tack feature requires wind information from one of our wind systems to work.
5. Could this unit also be controlled by any of your wired remotes, or the new wirelss remote?
==> This pilot will work with any of our ST remotes or both of the new wireless remotes.
Thanks for very quick feedback. One last question. Are any of your other Tiller Pilots, (ST2000 or ST4000) waterproof or capable of exposure to weather, waves or washing? If YES, are they capable of electronic stops?
==> Both are water resistant, but neither have the ability of electronic rudder stops.
