Welcome sailor! I have my X-boat on the west coast, but my parents live near you, in Edgewater MD. And another member here, Tony D, is also in Mayo. You can use the Location field of your profile to also record your boat & motor details.
Assuming that you don't want to get wet
the most common approach is to drop the CB on the trailer. The hanger bolt is accessed thru the forward dinette seat, just atop the CB trunk. The hanger is securely attached with 5200 adhesive, so various methods are used to break it free (sledge hammer, chemicals, or prying it free from the bottom w/a 2x4). This drops the forward CB to the ground, permitting the aft board to clear the trailer bunks. You can use the old line to pull a new one through the compression post to the cabintop.
There was a post on exactly your question about the inventory of lines.
Search on the terms [length of mainsheet], & click "all terms."
Moe (July'05) wrote:From PowerSailingCenter's Replacement Parts List:
5/16" White Economy Polyester Yacht Braid
Mac324 Furling Line (3/16" x 43ft) $13.75 ea
Mac325 Genoa Sheet (66 ft) 26M-X $33.00 ea
Mac326 Jib Halyard (50 ft) 26M-X $25.00 ea
Mac327 Jib Sheet (46 ft) 26M-X $23.00 ea
Mac328 Main Halyard (60 ft) 26X $30.00 ea
Mac330 Main Halyard (64 ft) 26M $32.00 ea
Mac329 Main Sheet (46 ft) 26M-X $23.00 ea
Mac331 Spinnaker Sheet (70 ft) 26M-X $35.00 ea
Mac332 Mast Raising Line (48ft) 26X $25.00 ea
Mac333 Boom Vang (12ft) 26M-X $6.00 ea
