What type of bottom paint for fresh water lake?
Posted: Mon Feb 13, 2006 5:39 pm
My 2004
was kept at a slip all last summer in a fresh water lake here in Minnesota...I thought I would try to get by without bottom paint.
I coated the hull with multiple coats of Poli-Glo (wax) to see if that would be the easiest way to go...I built up a moderate coat of slime, which pressure-washered off but I still had to use a 3M hand brush to get all of it off.
I checked the hull afterward, and didn't find any blistering (TG).
But all of the other sailboats at my marina had bottom paint.
Interlux paint corp. states that I should put six coats of their epoxy on first as an anti-osmosis, anti-blistering coating, then follow up with two coats of ablative anti-fouling paint.
West Marine suggests that I can just put on two coats of anti-fouling and I won't have to worry about blistering if the anti-fouling paint is good.
My question is for anyone who keeps their
at a slip in fresh water...what types and sequences of paint do you recommend?
