Hi Ixneigh!
Local servicing is a great thing to consider!
We started with a 2001 Tohatsu 50 hp two stroke when we got Over Easy.
The fuel consumption of two strokes and maintaining a 2001 engine twenty plus years later were problematic for us.
So after much researching, asking, looking, reading, calling around we chose to go with a 4-Stroke electronic ignition Suzuki DF60AV for our replacement engine.
Yamaha followed by Honda were our alternatives.
The Suzuki was our choice based upon our mixed salt water / fresh water utilization with the greater majority anticipated to be in Salt or brackish water. Serviceability was also a prime consideration. (Lots of places locally here in SC, NH, VT and along the ICW.) Replacement parts availability is not a problem either in-person or online. The reliability history was also very strong.
Tohatsu has very nice 4-stroke electronic ignition engine options and tended to be lighter than the Yamahas and Hondas.
About the same as Suzuki.
Our choice was the number of service providers in our planned operational locations.
Another aspect was the anticipated salt water operations where Suzuki seems to have an excellent reputation.
We do flush our engine when we come in from a day out on our local SC waters which are primarily salt water or brackish water.
Quick and easy fresh water flush connection is readily accomplished without fuss when in our marina slip or when enroute on the ICW when traveling as we have stayed in marinas. It really makes a difference in minimizing any salt build ups as evidenced when doing our annual maintenance checks. There are both internal as well as external sacrificial engine anodes on the Suzuki. These are available in Zinc, Aluminum and Magnesium so one can Taylor them to one’s operational environment.
The inspection, selection and changing of the sacrificial anodes is the key to a long and happy engine life, particularly for any engine operating in a salt or brackish water environment.
There are also aftermarket products like ‘Salt-Away’ that can help remove internal deposits if one’s situation only periodically allows one access to fresh water for engine flushing.
Best Regards,
Over Easy
