AIS Antenna VSWR Fault
Posted: Tue Jul 23, 2024 2:27 pm
by Starscream
I need some advice, please. I recently added a Raymarine AIS transmitter to my network, and it works great as a receiver. Problem is that I get a VSWR fault when I installed it.
So, I replaced the entire antenna system with the following parts: The AIS has a coax output to share the signal with the radio, and that is a short loop from the AIS to the radio right beside it, that should have nothing to do with the AIS transmission.
And I STILL get the VSWR Fault. Well, 3 out of 4 times that I start the network I'll get the fault, and 1 out of 4 it'll just boot right up. I haven't checked on the shiptracker website to see if I'm transmitting or not, yet. Any help or advice would be much appreciated.
Re: AIS Antenna VSWR Fault
Posted: Fri Jul 26, 2024 6:28 am
by Hamin' X
What is the model number of your AIS unit?
Posted: Fri Jul 26, 2024 8:08 pm
by Starscream
Hamin' X wrote: Fri Jul 26, 2024 6:28 am What is the model number of your AIS unit?
It's the Raymarine AIS700
Posted: Sat Jul 27, 2024 7:49 am
by Hamin' X
I would first check the software version on your unit. Latest version is: v01.17.01, available HERE. Next, I would check all your grounds. Antenna mount to mast, etc. If you know any ham radio operators, have them run an SWR check on your system. All manuals and guides are available HERE.
From the AIS700 trouble shooting guide:
3.3 VSWR Alarm troubleshooting
If you experience regular VSWR alarms try the troubleshooting guidance below.
Incorrect antenna in use.
Check that your antenna meets the required VHF antenna specification that can be found in the product documentation.
Antenna short or open circuit.
Check antenna for short or open circuit, repair or replace as necessary.
Product running an older version of software
Software version 1.09 included Improvements to Antenna fault detection (VSWR alarm).
Posted: Thu Sep 05, 2024 7:12 am
by Starscream
Happy to report that the VSWR fault has entirely gone away, and I can see my boat on Shiptracker. I don't know what changed to get rid of the error, but it's been functioning perfectly for weeks now.
