AmandaRuth wrote: ↑Wed Jan 04, 2023 5:39 am
Questions about my bilge heater and golden rods: I have the golden rods and bilge heater plugged into shore power for the winter. Are there any fire risks with golden rods - seems more like an ambient heat, but I worry about anything touching them. At what temperature does the bilge heater turn on? I read 45 degrees but when I've been to the boat in those temps I don't hear it running and my bottles of water near that compartment are frozen. The green light is on the bilge heater, indicating that it is working. (link to the type of bilge heater I have is below.)
Golden Rods - see I don't know what is "normal" for winterizing boats, and my friend was super innovative with retrofitting the boat. I wish you all lived here so I could show you everything he did. For example, he redesigned the rudders with clamcleats so they pop up if I hit a log/stick, which is common on my waters. That way I don't drag the log or even worse have the 70hp engine prop hit it. Yes, I said 70 hp - I don't think that was standard either.
Here is a link to a golden rod - apparently they are used for dehumidifying primarily - but I have 3 plugged in inside my cabin flooring.
This is a bit of a rabbit hole, but hang in there and we'll run it down.
What temperature do you want to maintain in the cabin? Do you have water piping/tankage in the boat that is not winterized?
The link you posted to your bilge heater indicates that it is safe to use in a bilge. Note the following:
"Meets all ignition protection guidelines and standards (USCG, UL-1500) to allow it to be safely used in the bilge compartment."
The golden rods, however, don't appear to have the same listings, or any safety certifications. Additionally, I find no reference to any heating capacity. The bilge heater is rated at 400 Watts, so you have something to work with there. I wouldn't use the golden rods in an unattended boat (or anywhere, actually - unless you find some listings on the device). Look for equipment that is tested/listed by safety testing labs/organizations.
If the unit has a fixed temperature setting (45 degrees), and the sensor is mounted in the device, the only place you can expect the temperature to be maintained is in the device casing. The unit may have the sensor in the fan air stream to try and sense the room temperature. However, depending on how it's positioned, it may just recirculate the heated discharge air and shut off before heating the rest of your boat. The more you seal up the cabin, or insulate, the more likely the temperature in the cabin will start to approach the thermostat setting. Where, exactly do you have the bilge heater mounted?
Have you made an attempt to seal the companionway/hatch gap?
What ambient temperature do you need to protect against (your worst case temperature in your area)?
Does the water around the boat freeze in the winter? If not, your ballast tank and hull mounted lines are probably protected by the surrounding water. If the water freezes around your boat, 400 Watts may not be adequate.
The golden rods, often sold under the very loosely used term, "dehumidifiers", appear to be small resistance heaters. They warm the air just slightly to raise it above the dewpoint of the outdoor air. So, they are not removing moisture, but merely attempting to prevent condensation. Where are these mounted and do you have any info on wattage ratings?
For any given enclosure maintained at a fixed temperature, with a fixed surrounding temperature, there is a balance point of heat applied/heat lost. In other words, if you want to maintain 45 deg F in the boat, floating in 45 deg F water, with 10 deg F ambient, it will take a certain amount of heating capacity (Watts, Btu/h, etc). If we move the boat to Russ's place at -40 deg F, we have to have more heating capacity to maintain the inside conditions. Knowing the conditions, the capacity required can be approximated.
For your bilge heater function question, the green power light being on may, or may not, indicate the device is functional. Plug it in outside in the cold and verify that the device actually cycles on. Step one, figure out what equipment or components are actually working. You can also get a non-contact infrared thermometer to put some actionable information together regarding what temperature various things are. I've done temperature and humidity control work for many years, and can get close to temperature and humidity by feel, but still use thermometers and psychrometers when I need to troubleshoot or verify.
