Page 1 of 3
New sailer and 26X owner - Running rigging help
Posted: Tue Dec 14, 2021 5:04 am
by FLMac26x-2021
Hi everyone, I am both new to sailing (ASA courses taking in October) and a new 26X owner. Unfortunately, previous owner did not sail, so buying boat was a blind process. Now I have boat at home and trying to figure out how to setup for sailing. ASA course was good, but boat was already rigged as a 36 Hunter. Now my question is what goes where on my 26x. It’s a 1997, looks like first owner did some upgrades but not 100% sure or was standard. I have the owners manual and downloaded some updated ones also. Read and re-read them, but they a “very basic” and don’t tell you anything really.
Can anyone help understand the setup of running rigging?
I’ve taken several photos of the pulleys, blocks, cam-cleats I have. Not photographed yet is the lines, but I also had a box of lines (running rigging) including 3 x “pulley” systems. 1 appears to be the boom as seen in manual, 1 is much longer and has cam cleat/2 pulleys, 1 long with 2 pulleys. I wonder if last 2 were original mast raising system (no pole) and another is some sort of boom vang?
I have a roller furler.
Question is what lines go where and what are all the pulleys/ other attachment points for from the photos?
Anyone have photos or diagrams of line setup, or if a 26x owner in south Florida so I can come take a look would be great.
Re: New sailer and 26X owner - Running rigging help
Posted: Tue Dec 14, 2021 5:43 am
by Jimmyt
Welcome to the forum and congratulations on your purchase.
Bottom pic is a feeder that helps guide the bolt rope into the mast slot.
You've either drawn the arrow the wrong way on your boom attachment point (mast) photo, or your attachment point is upside down. The hook and U-bracket should be on top.
Boom pulley may be part of a single-line reefing setup, or possibly lazy jack system. I don't have either, so I'll let someone else clear that up.
Post photos of your other questions. Lots of very smart X Owners here. Someone will be able to tell you what's what.
Posted: Tue Dec 14, 2021 6:15 am
The main sail attaches here (from your pic rotated)
From the 26M manual showing how the boom attaches.
Posted: Tue Dec 14, 2021 7:55 am
by Be Free
First of all, welcome to the forum and congratulations on your new boat!
I have nothing to add to the replies above. They are all spot-on. If you would care to share what part of Florida you are in it is possible that one of us may be close enough to come help you sort out your rigging.
Posted: Tue Dec 14, 2021 11:17 am
by FLMac26x-2021
Many thanks for reply's, yes pic could be wrong way round, its laying down right now and I was inside added text ;)
I took about a dozen pics, thinking I could upload all, only to find out limited to 3 per post(?).
As I said, on ASA, boat was rigged, and we learnt that boats setup, but I see I lot of differences (training had block of 3 or 4 rope clutch, 26x has single)
So I am struggling on what goes where. And the manual is useless on details.
Adding more images now:
I will split - maybe to try to group (port/stbd/mast)
Posted: Tue Dec 14, 2021 11:21 am
by FLMac26x-2021
Next images I would like to know what lines go where...
Posted: Tue Dec 14, 2021 11:24 am
by FLMac26x-2021
more pics / question of what for..
Posted: Tue Dec 14, 2021 11:25 am
by FLMac26x-2021
And mast pics
Posted: Tue Dec 14, 2021 12:17 pm
by Jimmyt
Your Genoa furling line goes through the block that you guessed was for the furling line, then runs through the fairleads and blocks, just inboard of the stanchions; all the way back to the cam cleat just outboard of your port winch.
Job/Genoa halyard and forestay connect to a hound (mast bracket) that's a few feet below the top of the mast.
Block nearest your mast track at the top should be your main halyard.
Looks like you have a boat that is setup for all lines run to the cockpit, so you may have to post some wider shots so people can see the various routes in total - rather than just the individual blocks. But, you may get lucky and someone might have an identically rigged boat.
Show a pic of your mast raising rig so we have a better frame of reference on that.
Posted: Tue Dec 14, 2021 12:33 pm
FLMac26x-2021 wrote: Tue Dec 14, 2021 11:17 am Many thanks for reply's, yes pic could be wrong way round, its laying down right now and I was inside added text ;)
Rope clutch is for main halyard. Cam cleat next to sliding hatch is for swing centerboard, and other cam cleat is for whatever you're winching, usually the jib sheet.
Posted: Tue Dec 14, 2021 12:36 pm
FLMac26x-2021 wrote: Tue Dec 14, 2021 11:21 am Next images I would like to know what lines go where...
Small block on lifeline stanchion is a fairlead for the jib furling line, as is the fixed bullseye fairlead. There should be a cleat just forward of the cockpit.
The twin sheave turning block starboard of the mast and the single on the port side are for various lines, depending on what's rigged back to the cockpit. One of the twins is for the main halyard, and they both go to the block on the stanchion, which (ahem) be done a bit better than a hose clamp. The other may be for reefing, or a vang, but I'm guessing a reefing line.
Posted: Tue Dec 14, 2021 1:03 pm
The question still remains, which block is for what?
Not having an :macx: , I am not familiar with the set up on the top of your mast. It appears that the block on the left could be for the main, and the block on the right could be for the topping lift?
Your photo cuts off the extension going to the left in the photo. Again, not having an :macx: , I can only think that is for the back stay?
Hopefully, now that I rotated the photo, someone with an :macx: might better explain it.
P.S. Where in Florida are you :?:
There may be an :macx: owner nearby who can assist. We are a helpful group.
Posted: Tue Dec 14, 2021 2:23 pm
The one near the slot is for the main sail halyard. My topping lift block is on the other side, opposite the halyard block.
I have no idea what that other forward block is for. If a topping lift went through it, the line would rub on the halyard block. Maybe it's for a spinnaker, but it's not oriented correctly for that, and it's too high up the mast. So I have no clue. :|
Image below is my mast, rotated so it looks like it's ready for work. The lump on the other side is the VHF antenna, folded for storage. If you zoom in you can see the smaller line which is the topping lift, and the small block (part of it at least) opposite the halyard block.
Posted: Tue Dec 14, 2021 2:30 pm
Tom,
Do you plan a vacation to Florida soon :?: There might be free lodging in it for you :?:
Posted: Tue Dec 14, 2021 6:07 pm
NiceAft wrote: Tue Dec 14, 2021 2:30 pm Tom,
Seems like every time I go somewhere and visit someone I end up doing work ha ha. :D
