This next one may be on me for not looking under the cowling closely at my engine before buying this 2005 26M
They advised the part is NLA (no longer available) from Honda and they didn't want to risk putting in a used or ebayed part. Kudos to them for being upfront and after talking a bit reassured me that if I found a carb, based on my level of experience, I should have no problem swapping it in. They even got me the exact part number and sent me on my way for a nominal (and reasonable) diagnostic fee.
Well, fast forward a couple days and I have found the full manifold may be available. Which has all three carbs and linkages, intake, exhaust, etc... So here's my question to you:
What would you do?
1. Swap the engine, for $4-7k boat gets a pretty new purrrr
2. Run as is, you may not get more than 8knots but hey, it's a sailboat too!
3. Get the manifold and swap it in, it's only $800 and a day of your time to restore the motor for another ten+ years of service.
4. Sell the boat, clearly you got a lemon and the pristine condition of the hull and everything else, well cut bait mate!
5. Start dialing every marine motor junk shop and see who has this motor and will sell you the carb for hopefully no more than it was new ($200)
6. Bring out the flippers, dive in and attach yourself to the transom, when you get her to plane, you've made it.
7. Something I haven't thought of?
Thanks in advance,
Toros
