Blew out my head sail tack
Posted: Fri Sep 10, 2021 7:53 am
by DaveC426913
Came back from a cruise and found this:
Sail tack has lost its hardware and come unattached.
Now I forget how to reattach it.
It should have a small D-shackle attaching it to the drum on the starboard side, just like the line on the port side, yes?
While I'm at it, this is just not right. The shackle's ring-ding has pressure on it, and the ring-ding is the only thing stopping the mast from coming down!
Suggestions? Pics of your setup?
Re: Blew out my head sail tack
Posted: Fri Sep 10, 2021 8:19 am
by PSNA
Posted: Fri Sep 10, 2021 3:42 pm
by rsvpasap
Don't just use a ring-ding.
Posted: Fri Sep 10, 2021 3:46 pm
by rsvpasap
Don't just use a ring-ding on the furler, suggest you use a genuine (tiny) shackle. And if the ring-ding on the bow attachment concerns you, use a larger one made of stainless or a thicker stainless cotter pin.
Posted: Sat Sep 11, 2021 8:59 am
by DaveC426913
rsvpasap wrote: ↑Fri Sep 10, 2021 3:42 pm
Sorry. Let's deal with my two issues separately.
1. The Headsail tack. I just need a small shackle.
2. The forestay/deckplate connection.
I'll use a larger ringding, but that won't solve the problem. There should be no pressure on the ring ding. The pin should not be angled like that.
I need to add spacers** or reduce the gap.
**which I really don't want to do because attaching the forestay at mast-raising time is by far the most labour-intensive thing I have on this boat - even though it's only once a year.
Posted: Sat Sep 11, 2021 9:00 am
by DaveC426913
Can you explain? Does the 90 degree twist shackle simply serve as an extender?
Doesn't this give you even more slop in your forestay under tension?
Posted: Sat Sep 11, 2021 10:20 am
by trdprotruck
DaveC426913 wrote: ↑Fri Sep 10, 2021 7:53 am
For the OP, on the forestay to deck connection. The ring ding should not have any pressure on it. The ring ding only prevents lateral movement so the pin does not slide out. I would just use some pliers on the furler connection and close the gap of the 'U' since it looks like it has spread out.
BWY has a longer pin with a larger grip on it that will also help.
Posted: Sat Sep 11, 2021 1:47 pm
by rsvpasap
The point of the photo is the placement of heavy duty ring dings. The one and a half inch twisted shackle was just to create space for an anchor to rest underneath.
Posted: Tue Sep 14, 2021 8:42 pm
by DaveC426913
trdprotruck wrote: ↑Sat Sep 11, 2021 10:20 amThe ring ding should not have any pressure on it. The ring ding only prevents lateral movement so the pin does not slide out.
Indeed. My concern exactly.
trdprotruck wrote: ↑Sat Sep 11, 2021 10:20 amI would just use some pliers on the furler connection and close the gap of the 'U' since it looks like it has spread out.
Maybe, but I think I did that once already, and I suspect the pull on the forestay will just straighten it out again.
trdprotruck wrote: ↑Sat Sep 11, 2021 10:20 amBWY has a longer pin with a larger grip on it that will also help.
Yes, I intend to get that.
Posted: Sat Sep 18, 2021 4:31 pm
by DaveC426913
OK, I went to replace the headsail tack shackle and found all my replacement shackles have pins that are too fat. So back to the chandlery for an even smaller one.
But that's not the scary part.
I found the port D-shackle (left in rsvpasap's pic) was popped and barely hanging on:
(This is not my pic, this is rsvapasap's setup)
According to CDI website, that is the "halyard assembly" (C, E and F in the diagram).
https://www.velasailingsupply.com/our-b ... are-parts/
So, worst case scenario, my sail might have slid down, but I would
not have been dismasted, yes?
The forestay is SS cable, not braided line.
Yeah. OK. So I wasn't 1/32nd of an inch from being dismasted. OK.
