How to tack in very shallow water.
Posted: Tue Apr 20, 2021 8:04 am
I’ve been enjoying my M in very shallow water and she will now sail on all points in any water she can float in. The stub keel reduces the strain on the rudders to manageable levels. Note I have the OEM “thin” brackets as well.
however she still won’t go about under just a main unless I use this procedure, which I’ve gotten good at and will also work in a pinch for unmodified boats.
Come onto the wind, sheet the main in tight, helm hard over, now pick up both rudders out of the water. She will go right around even in the shallowest water. Drop the rudders once you’ve gone about.
I usually use just the main in real shallow places to keep speed down. In this case I was successful tacking the boat with just a double reefed main in 20 K of wind, and working my way up wind in less than two feet of water.
The stock M would sail somewhat in shallow water but not something I’d want to do for miles. I still would for short distances like cutting across flats and things, before I made my additions. The tacking was an issue though. The rudder truck solves that.
Ix
Ix
