Page 1 of 7
Max Horsepower for '01 26 x
Posted: Sun Sep 01, 2019 2:06 pm
by PopeyePete
1)What is the maximum horsepower I can put on a 2001 26 x?
2) What engine would be the best to achieve it?
3)What speed (with and without water ballast) can I expect to get?
4) would it have enough power to pull up a slalom skier?
Re: Max Horsepower for '01 26 x
Posted: Tue Sep 03, 2019 6:27 pm
by LeePierce
Not sure about "biggest", but... when also considering price, weight, reliability...
I went with an older Johnson/Evinrude 120 two stroke V4 (not the V6).
Super reliable, super common, and EVERYONE seems to know how to fix them.
It looks like it belongs there. If you go with a taller V6 or the even taller Mercury, it will hit the drivers seat when you tilt the engine up.
I am playing with the prop's but so far it seems to move well with the balast in, I have not tried a run without the balast yet.
One issue, the honda 50 was balanced so the steering was neutral while the motor was up, this engine weighs enough to cause the wheel to spin when the engine tries to flop to one side. I have bought a steering disconnect but have not put it on yet.
As I get the prop dialed in, I will start reporting the speeds.
Lee
Motor
Posted: Wed Oct 09, 2019 8:05 am
by Sheppie62
50hp
Posted: Thu Oct 10, 2019 8:56 am
by Seapup
I ran a 2003 suzuki DF90 (older 1950cc 400lb 4 stroke) on my X for a few years. I also had a 2003 honda 50 and 2015 suzuki DF20a on it. I have a yamaha 70 on my skiff. The yamahas seem to be a little smoother to me. The 90 is a great match to the x. My experience is stay at 9.9 or jump to at least 70. In general every few years manufactures come out with a new model, lighter, faster, supposedly better. I am a fan of the newest engineering if I can afford it and would take that over manufacture branding. Generally they try to outdo the competition and won't release something that has problems, so they are all fine. I like the just released T25 yamaha for another boat, but gave up on it ever coming out and bought a new T9.9 last year.
My experience was the weight does not matter that much on the transom of the :macx: . The difference between 200 and 400lbs was not that noticeable. I don't think 20-30lbs up or down on a 90hp on a X would be noticeable at all. I could not fathom it before the install and only did it because a few others had the identical motor.
The seat interference is the cowling on the trim on the back of the seat, a little cutout of the back flap of the seat and that is taken care of. The mercurys in my opinion have a huge cowling. They look much larger in person than the others to me. There are a couple at my marina. I have not seen the new yamaha 90 in person, but the curve on it should keep it pretty compact.
Top speed should be about the same no matter the brand if they are producing the rated hp. My experience is the larger CC do produce the torque lower in the RPM range so you can run the same speeds at lower RPMs. I would put more importance on displacement and available props (large diameter and large individual blades) than weight of the motor.
Posted: Fri Oct 11, 2019 3:16 am
by dlandersson
Are there any 60+ HP outboards that allow for manual pull starting?
One of the reasons I haven't explored an upgrade is because that's as big as it gets and still allow for manual pull starting if necessary. I am an old sailor, not a bold sailor. :wink:
Motor
Posted: Fri Oct 11, 2019 10:54 am
by Sheppie62
50hp
Motor
Posted: Tue Nov 12, 2019 10:07 am
by Sheppie62
50hp
Motor
Posted: Tue Nov 26, 2019 9:39 am
by Sheppie62
50hp
Posted: Tue Dec 10, 2019 2:59 pm
dlandersson wrote: Fri Oct 11, 2019 3:16 am Are there any 60+ HP outboards that allow for manual pull starting?
The ETec is an amazing motor in that it can be pull started with a flat battery.
I have one of these on the boat and in all the cars. Wally World sells them for around $50.
Our motors will start with a motorcycle batter. This jumper started my truck on a cold single digit weather day. Amazing.
https://www.amazon.com/Longma-Portable- ... r_1_3_sspa
Posted: Wed Dec 11, 2019 4:55 am
by dlandersson
Ok, I'm confused (happens a lot). You mention your etec can be pull started, then immediately address using a lithium battery jumper (I use the Genius one). :o
Posted: Wed Dec 11, 2019 1:26 pm
dlandersson wrote: Wed Dec 11, 2019 4:55 am Ok, I'm confused (happens a lot). You mention your etec can be pull started, then immediately address using a lithium battery jumper (I use the Genius one). :o
I don't have an eTec.
But I remember Matt S told of testing this with his. He was able to pull start the eTec. Even with a totally dead battery.
He went on to explain that the motor is able to make enough spark to start that way. I presume a magneto or some such thing. It's a very high tech computer-controlled motor, yet can start without juice. That's amazing to me.
For those of us with lesser motors (I have a Suzuki DF70), the jump pack is a good solution. Or those with weak backs.
Posted: Wed Dec 11, 2019 9:26 pm
by DownSouth
I know this has been mentioned in previous similar threads but some :macx: manuals state pretty clearly "The boat is designed for an outboard motor of no more than 50 horsepower. Do not use a larger engine".
Of course this may or may not have any consequence to you or the operation of your boat, and implications would likely be different in different countries and juristictions with rules and insurance policies that may be affected.
I always thought the threads on what is the minimum hp were interesting as well....
Posted: Thu Dec 12, 2019 3:55 am
by NiceAft
DownSouth wrote: Wed Dec 11, 2019 9:26 pm I know this has been mentioned in previous similar threads but some :macx: manuals state pretty clearly "The boat is designed for an outboard motor of no more than 50 horsepower. Do not use a larger engine".
I believe the restrictions stated in the manuals ( both X & M) had to do with warranties. On page 21, section 27 of the X manual it states to not put a motor larger than 50HP on the boat. Those who have much larger motors, in many cases, have reinforced their transoms.
Later models of the M were suggested to use a motor no larger than 60HP. My 2005 :macm: manual says 50HP.
Posted: Sun Dec 15, 2019 1:55 pm
by mallardjusted
The reasons for the manufacturer recommended 50HP maximum was listed in their advertising brochures:
from MacGregor 26X web page, @ 2002
We limited the engine size to 50 hp for a number of reasons:
1) An electric start 50 hp motor provides lots of speed, yet is light enough so that sailing performance isn't compromised.
2) It is about the largest engine that can be started by hand, a nice feature if your battery goes dead.
3) It is about the largest engine you can pick up and move around. Try getting a 100 hp engine off the boat & to a repair shop.
4) Also, the heavier, higher horsepower engines really eat up gas.
This is outdated information, as newer 4-stroke engines have evolved. My 70hp Yamaha weighs essentially the same as 50s back in the early 2000s. Power packs can now be easily carried to start engines. The newer engines get much better fuel economy.
Posted: Sat Dec 21, 2019 2:52 pm
by DownSouth
Yes I was always curious over the start by hand comment I wonder how many outboards of 50hp could actually be started without power?
