Hull to deck joint repair
Posted: Sun Jul 21, 2019 4:12 am
Hello all,
I am in the process of restoring a Venture 17 and have to replace the sealant between the deck and hull. The boat is currently sitting upside down on stands and I've removed the rails and what was left of the sealant. I have to keep a few screws in place to hold the hull in the proper position or it'll slide down further into the deck. I plan on using 5200. Question: Should I draw the joint together and leave about a 1/4" gap, add sealant, cure, and then snug? Or would it be ok to snug while the sealant is 'wet'? I'm concerned about sealant sag into the boat (being upside down it'll flow into the cabin) and being able to hold the hull in the correct alignment to the deck. My other thought was to get flat head screws and install them to hold everything together leaving them in place under the rail. Otherwise, if I don't use flat heads spaced between the existing holes, then I have to remove them to install the rail.
Thoughts? Suggestions?
