How to fix a leak in a stock bow light?
Posted: Mon Feb 25, 2019 9:28 am
by Alexis
Hi,
I noticed after a rain or after having washed my boat, that a little bit of water is entering from the bow light of my 26x. It is the original (cheap) light which is screwed on the deck.
I am throwing a question to the group before I make the decision to upgrade : is there a way to make it water tight? Maybe a little bit of caulking ? Or by adding a rubber gasket?
Thanks
Re: How to fix a leak in a stock bow light?
Posted: Tue Feb 26, 2019 6:31 am
by paul I
Posted: Tue Feb 26, 2019 9:33 am
by rsvpasap
If the light is fully functional and its appearance is acceptable, remove and rebed it using 5200 sealant.
https://bit.ly/2Vl2I4j
https://www.amazon.com/dp/B0000AY6CA/re ... il_2?psc=1
https://thd.co/2GNfgOG
Posted: Tue Feb 26, 2019 10:12 am
by Chinook
They're kinda tricky to remove. I don't recall exactly how the screws work, but I think there's a compression fitting the screws set in, which can fall off. You might check with BWY on how to remove and replace.
Posted: Tue Feb 26, 2019 11:04 am
by Alexis
Yes, it has to be this one. The one on my boat still looks good, though of course the plastic has been UV cooked a bit over the years... This picture made me guess that the flat bottom surface must the culprit: this design is lacking a seal.
Posted: Tue Feb 26, 2019 11:06 am
by Alexis
rsvpasap wrote:If the light is fully functional and its appearance is acceptable, remove and rebed it using 5200 sealant.
Yes, I think this will be the plan for this year!
Posted: Tue Feb 26, 2019 11:11 am
by Alexis
Chinook wrote:They're kinda tricky to remove. I don't recall exactly how the screws work, but I think there's a compression fitting the screws set in, which can fall off. You might check with BWY on how to remove and replace.
Thanks Chinook, I will check that too!
