This is not solely my idea/work (thanks Tom!) but please note I take no responsibility for any modification you make and I am NOT recommending you do this. If you think this mod is dangerous then please DON'T DO IT.
This is my Spreader bar kit bag. Actually it's just a nylon bag I got off of my $20 Spirit Level but it stops me knocking the bars around the inside of my Mac
Firstly you are going to need a Square Wire Lock Lynch Pin. It has a diameter of 9.3mm and is 75mm long ... You may notice that my one is not Stainless and I'm still trying to find one this size in Stainless ... Mine is not showing signs of corrosion but it's best replaced annually or bi-annually at least.
Yes I use the Lynch Pin instead of the pivot nut and bolt on the spreader bracket. Some of your may be concerned but I've inspected the pin for wear after each Sail and it's holding up really well.
You might note that I still have the traditional nut and bolt holding one of the spreader bars in. I only pull out one bar/side so the other sides nut and bolt stays there permanently.
