Does anyone know what this pipe is for?
Posted: Wed Jun 22, 2016 3:05 am
by sunshinecoasting
My 2000
has this pipe in the rear birth on the starboard side, I have no idea if it is a factory fitting or done by the PO and I certainly don't know what purpose it has/had. Click on image to enlarge.
Re: Does anyone know what this pipe is for?
Posted: Wed Jun 22, 2016 5:27 am
by Cougar
It's factory standard. You can run cables and wires from the stern through it. The other end is on the starbord side of the motor well / transom.
Posted: Wed Jun 22, 2016 6:01 am
by Retcoastie
Correct. In fact, my steering cable goes thru the larger one.
Posted: Wed Jun 22, 2016 6:16 am
I can't get over how clean and shiny it is back there.
And I have some wiring running through mine, though my steering and engine control push/pull cables go through the other hole, where yours are.
Posted: Wed Jun 22, 2016 1:31 pm
by DaveC426913
I have a 2000
as well. My steering and throttle cables run through there.
I'm curious why/howe yours do not. Yours seem to emerge from the engine well.
Can you post a pic of your well from the outside? I'd like to see how your cables connect. Do you find it works well/poorly that way?
Emerging from the stb transom is actually awkward. Not only do the cables get in the way, but they bend at an off angle to attach. When I move the OB up/down, the cables spring back and forth.
Posted: Thu Jun 23, 2016 12:52 pm
by Starscream
It's to let mosquitoes in at night.
I had to plug mine to stop the invasion. I didn't know what it was for but it was the only place I could find that they could be getting in. After that...peace.
