M25 trailer tires and wheel size
Posted: Sat Jun 18, 2016 7:41 am
I just purchased a 1982 M25 and single axle trailer. It will need a lot of clean up and I also want to do a thorough visual inspection of both the boat and trailer. The unit wasn't used since approx. 1997 so I know that the tires shouldn't be trusted. The tread is perfect but there is some dry rot in spots. The tires now are Chaparral S/T steel radial, 6 ply, max load 800 kg. (1760 lbs), ST205/75 R14. Can someone suggest a good tire but not too expensive. I may not use the boat much and will only need to tow it about 50 miles when I do.
The rim is a 5 lug version. Has anyone found a spare rim at a junk yard? What vehicle would use this size wheel?
