Page 1 of 7
Guess I have to learn how to sail now.
Posted: Wed Jun 15, 2016 5:31 am
by taylormade
Again, thanks so much for the feedback and advice on my 40 vs 50 thread http://www.macgregorsailors.com/phpBB/v ... =9&t=25427 and when I was trying to narrow my selection to a particular range of years http://www.macgregorsailors.com/phpBB/v ... =9&t=25270.
I've been looking for the past six months and two weeks ago I decided I was going to quit looking, focus on selling my wakeboard boat, and do projects around the house and maybe revisit this search in the winter or a few years from now. What I DIDN'T do apparently was turn off my Craigslist search notification. Thank God I didn't, because I wouldn't have found this 99 X.
At $9,900, it was already several thousand below any other :macx: I'd seen in the past six months of searching CL, Boat Trader and Pop Yachts. Most 99-02s are in the $13,500-$15k range on the west coast of Florida. When I saw the tandem aluminum trailer, I thought "Run!! RUN, SCOTT RUN!!!" I made the hour long trip over to check her out and saw exactly why she was priced so low. She's seen some pretty good use. Lots of dings, dents, repairs, etc. There's quite a few spots where amateur fiberglass repair was been attempted, both inside and out. It had the 40hp motor instead of the 50... it doesn't have a roller furling, no electronics, the front windows were shot and spiderwebbed, the bimini hardware has been ripped out of the hull and there are now just holes, the list goes on and on. They're all small things that are mostly cosmetic but could easily point to a boat not being taken care of properly, which I tend to run away from. I've definitely never purchased a boat (or anything for that matter) in this condition. I walked away after looking at it with some certainty that I'd never see it again and told the wife that it was in bad shape and we knew now why it was priced so low.
We went to look at two others, that touted their pristine condition, in nearby towns. Both had the 50hp motors, both had the roller furlings, both had better ladders inside the cabin, both had nice lights on the mast and both had GPS systems with bottom finders. They were both very clean, shiny and, in general a lot better shape than the :macx: I'd seen days before.
But, both also had the standard steel Mac single axle trailers. Both were showing a good amount of rust and I'm terrible at making sure I thoroughly rinse off my trailers, so I knew they'd be toast within a year. Both had their bumps and bruises and holes on the interior of prior, failed mods or electronics. One needed new rigging and didn't have the cockpit cushions, the other needed a new mainsail. The divide started narrowing quickly in my head and I started wondering if I'd made a mistake discounting the first :macx: I looked at.
I called the owner, a super nice guy btw, and asked him the condition of the cushions, the sails, etc... things I hadn't bothered doing prior since I'd already written the boat off. The three sails were like new, cushions were too! He'd just put a new marine radio and antenna in, swapped out the dual batteries and installed a perko switch. It's got an inverter and shore power too! I realized that the negative differences between the three boats were mostly cosmetic and that's something I have the ability to fix myself and that the positives greatly outweighed the negatives and with a HUGE delta in price, my mind was made up.
We negotiated a price we were both slightly uncomfortable with which, to me, is always the sign of a fair deal. The more I find out about the boat, however, the more I realize what a screaming deal I got (this all said, of course, before the boat ever hits the water).
Alright, enough of the babble, let's see this baby!
Re: Guess I have to learn how to sail now.
Posted: Wed Jun 15, 2016 5:46 am
by taylormade
Posted: Wed Jun 15, 2016 5:47 am
by taylormade
Posted: Wed Jun 15, 2016 10:14 am
by Bilgemaster
Looks like you did well from here...certainly if you got it for much less than that $9,900 original asking price. A pretty much unmolested, if slightly dinged up 26X is a wonderful blank canvas to play with, even with that little Honda 40. After all, most sailing folks get along happily with far less "OOMPH!" on the stern than that.
As a rank newbie to this whole sailing "thang", most any recommendations I might offer should be considered provisional hunches at best. Still, I can tell you with at least some personal experience that a roller furling jib with nice long sheets led aft seems a fine thing...So you might want to start looking around for one. There have been plenty of discussions in these forums on the matter, but this one seems particularly helpful. For the record, mine came with a CDI Flexible Furler 2, and the guy I'm getting occasional sailing lessons from remarked on just how well it worked. Info and manuals for all their various furler models can be found on the manufacturer's website at http://www.sailcdi.com/products/flexible-furlers.
As with most of the other gear you'll ever likely need, the good folks at Blue Water Yachts in Washington State can square you away with a nice new CDI furler (though other furlers, used or new from elsewhere may also work). Their website is still sort of "partying like it's 1999", but their Parts Catalog's found at http://bwyachts.com/BWYParts/info.htm. My advice: add a 5 pack of "ring dings" to each and every order for just $1.50. Don't worry about what they are. Just add them to the order. Do it. Trust me: You'll want them. You'll need them.
And Hey...What's with the dock? Did that come with the boat? Is that its new home? 'Cause I want to be in that chair with a cold Yuengling waiting for the sunset RIGHT NOW!!!
Posted: Wed Jun 15, 2016 10:51 am
by yukonbob
I would recommend being new to sailing that you get a clinometer (tells you how far over the boat is when heeling) and remember that you can lay the thing flat on the water with the ballast in. It can be unnerving the first few times you set the sails and boat goes over, at least you can look at it and say, 'Oh we're only over 30 degrees we're ok still :D ). Nothing to be concerned about it just feels wrong especially if you're coming from a power boat. Its cheap piece of mind. That and see if there are other Mac owners in your area and get out on the water with them for some sailing time to get the feel of it.
Posted: Wed Jun 15, 2016 12:30 pm
by taylormade
Excellent advice on the furler, and I really appreciate the links. I'm pretty sure the salvage yard near me has everything I'd ever want as it's insanely big. Anyway, I'll get on the hunt for that quickly. In fact, one of the sails included is already set up for that... makes me wonder what happened to it.
I got it for $8k, which I'm thrilled with. Trailers like that go for $2500 used around here, with new tires, brakes and are $4000 new. Here's a 22' for $3500 http://tampa.craigslist.org/pnl/bod/5628433716.html. The engine? It's probably worth $2k-2,500 used from what I'm seeing. The cowling is in crap shape, but the insides look good and it has good compression. He had receipts for all the service done, recently replaced the water pump and impeller and I was comfortable with the barrel test.
I'll pick up a clinometer along with another compass since the one in it is shattered, thanks for that and I agree, it's good for peace of mind for sure!
WADR to whomever's dock that is, I'm sure it's nice, but I'm happy to say that's NOT her new home, I don't like looking at my neighbors.
HERE'S here new home!
Interesting sidenote: I lived in Woodbridge and went to elementary school there before moving to Stafford. I know NoVa very well. Actually I was in DC/Alexandria every other week from October - Jan this past year. Man, what a difference from the 80s/early 90s to now!
Posted: Wed Jun 15, 2016 3:05 pm
by sailboatmike
Actual sailing is easy, sailing well is much harder.
Sailing just requires a decent angle to the wind and pull your sails in that will get you moving, getting the best out of the equipment is another thing including constant adjustments to the helm and sails as the wind shifts, gusts and lulls.
Most of us strike a happy medium, some just like to enjoy the sensation of sailing and dont care much about making adjustments.
But I must say the first time under sail you will marvel at the ability of the boat to make way with just the power of nature, for me its a feeling I will never forget
Posted: Wed Jun 15, 2016 5:20 pm
by DaveC426913
When considering the price versus the cost of refurbishing, you can console yourself with the idea that you're simply buying a $15K Mac that's only $10K down, and $5K over the next five years, as you fix it up. :)
Posted: Thu Jun 16, 2016 5:03 am
by Ixneigh
You can't sail the boat with out a few dings and boo boos. If you sail it a lot you get a lot. So the last thing I'd worry about is a few scratches. Rigging sails motor and bottom. Those are important!
Best of luck and happy sailing!
Ix
Posted: Thu Jun 16, 2016 5:49 am
by sailboatmike
Ixneigh wrote:You can't sail the boat with out a few dings and boo boos. If you sail it a lot you get a lot. So the last thing I'd worry about is a few scratches. Rigging sails motor and bottom. Those are important!
Ix
And of course keeping the water on the outside :D
Posted: Thu Jun 16, 2016 6:29 am
by taylormade
sailboatmike wrote:Actual sailing is easy, sailing well is much harder.
Yeah, we've been watching youtube videos and reading books for a few months now, plus our friends have a ridiculous catamaran, so I've done SOME sailing (if you can call it that). I at least know how to raise the sails, so that's a start lol. I'm supposed to take delivery of it today and I'll be working with the PO for a few hours I'm sure learning how to raise the mast and get it situated. I am very excited to turn the engine off for the first time, but it might not be for a few weeks until I feel comfortable. I guess worst case (assuming there's ballast, ha), I could just drop the sheet and turn the engine on, turn into the wind and drop the sail.
DaveC426913 wrote:When considering the price versus the cost of refurbishing, you can console yourself with the idea that you're simply buying a $15K Mac that's only $10K down, and $5K over the next five years, as you fix it up. :)
Yep, and it's much better if you buy it for $8k and put in $3k over the next five years!!
Ix
Yeah, I assure you, I'm not worried. In fact, I'm a bit relieved honestly. I had a friend who'd buy a new truck and when he got it home, he'd hit it with a hammer and put a ding in it so he didn't baby it and he was at least responsible for the first dent. Seems crazy to me, but with this boat, I'll have NO problems grabbing the hole saw and getting to work.
Posted: Thu Jun 16, 2016 9:03 am
by dxg4848
First sailing experience could be a little intimidating (at least it was for me). I would suggest you not taking your wife or small kids when you are ready to try it first time. Extra set of hands is helpful, so bring a friend with you.
Triple check that water ballast is full. With water ballast full your won't capsize boat no matter what.
Ideal wind to try sailing with both sails is 10 - 12 mph breeze. If wind is 12 - 18 mph then reef main sail at the dock so you won't have to do it out on the water.
Wear life jacket in case you have to go to bow or on top of cabin if something goes wrong.
Posted: Thu Jun 16, 2016 9:33 am
by dlandersson
Looks and sounds like you got quite a deal. 8)
Posted: Thu Jun 16, 2016 10:00 am
by Obelix
Welcome to the group, as a new MAC owner. :)
If you're looking to connect with other trailer sailors in the area, here is a link to the "West Coast Trailer Sailor Squadron" . This is a friendly group with several interesting outings during the season. Take a look at some of the videos in the link.
http://members.ij.net/wctss/wctss/
We have several :macx: , :macm: and classic Mac's in the group.
Obelix
Posted: Thu Jun 16, 2016 11:25 am
by dlandersson
Have a clipboard with a checklist. Nothing wrong with it. Pilots do it. :wink:
dxg4848 wrote:First sailing experience could be a little intimidating (at least it was for me). I would suggest you not taking your wife or small kids when you are ready to try it first time. Extra set of hands is helpful, so bring a friend with you.
