My old v22.2
Posted: Sun Jun 12, 2016 6:35 pm
Looks like my old boat may be on the verge of being abandoned or coujd be had for a few hundred at most.
On the last assessment:
All 3 masts are present and intact. Sails are fair to poor. Keel is good but needs fairing and some glassworks due to grounding. Does not need to be removed. Inside is a mess but salvageable. It no longer has the stock venture interior.
Lower rudder blade is gone. Fairly easily to make that. Hull and deck need to be repainted due to unfinished mural art.
Area where the boat impacted rocks could use few more passes of glass but there are no leaks and I did a pretty good job on it. The wiring needs to be replaced but that's no biggie. The upper hull and deck are good with no dock dents, or mashed fiberglass.
This boat was very cute with the three masts. I had a lot of fun on it. The sails were painted so I did not have to cover them. I could get the boat underway in five minutes. It was actually easier to sail the boat then to start the motor. The main can be easily replaced with any sail that has the correct foot. The upper part of the sail is cut off at the needed luff length and then the upper sprit is bolted in place. (The cloth is rolled twice and the two halves of the Sprit sandwich it)
All needed deck hardware is present. Boat is sailable except for the missing rudder blade. I might be convinced to donate one of my old factory M rudder blades to the cause. Although a new idarudder setup woukd be the best. The boat can be seen on YouTube I think it's still up. Search for "unicorn lugrig"
Boat has no trailer also.
Ix
Ix
