I'm rewiring my house system. When I look at wiring diagrams in the archive, it looks like I should run a negative wire to the item (like running lights) from the switch panel, but also run a negative line directly back to the battery.
Is this right? 3 wires? I thought that pos and neg off the panel would work.
Thanks for any guidance.
--john
Electrical Grounding for the house system
Re: Electrical Grounding for the house system
I don't know where that came from, but that's not required. It only takes two conductors to make a circuit, and you can, and normally will, bring the negative conductors back to the switch panel. Land them on a bus bar for neatness (or bolt them all together like MacGregor did
), and run a single line back to the battery bank. Size that conductor for the total current of all devices connected to that bus/bolt. Same with the positive conductor - size it for all the loads it carries, combined. Voltage drop may govern, and remember that voltage drop is calculated over the total out-and-back run. But if it's only lights, voltage drop isn't all that important, unless it dims your nav lights, of course.
That's all assuming you're talking about the 12V system, not 120V shore power.
Interim
Yes, 12v system. Sorry.
And thanks. Simpler is better for me. Gosh, I might even get to do some night sailing this year!
--john
--john
- Wind Chime
We have the factory wire (+/-) running from battery(s) to our panel(s) and the negative is still factory single ground pole behind panel.
Thinking ahead; if we are increasing the load to the panels and require additional voltage we may need to max out the voltage to the panels by increasing the AWG size from battery to panel.
Stupid question: we could just run a larger AWG (+/-) wire, or could we also leave the existing wire and run an additional wire with the same AWG size as existing one? Does 2 smaller AWG wires = one larger AWG wire??
- seahouse
I have wondered the same thing Wind Chime, because it would seem that two wires (assuming equal conductor cross-sectional area), better able to dissipate heat, would actually have an increased carrying capacity over one single large one. (Extra terminal connections not considered).Wind Chime wrote:We have the factory wire (+/-) running from battery(s) to our panel(s) and the negative is still factory single ground pole behind panel.
While you could parallel conductors, which will halve the current and voltage drop for that run (assuming same material and gauge for each), there are potential hazards. Like losing continuity in one conductor, which results in doubling (assuming two conductors) the current and therefore the voltage drop while increasing the heating in the remaining conductor. The National Electric Code prohibits doing that for conductors smaller then 1/0, except in certain circumstances, but those circumstances require each conductor to be able to carry the entire load (Art 310). Granted it's 60Hz power and control wiring, and we're not talking about wiring a building, but there are valid reasons not to do it that still apply to DC wiring.
With such a low voltage as 12V, voltage drop is likely a bigger concern than heating in the wiring, which the insulation is designed for anyway. A 1V drop (out and back) is 8.33%, which is a lot. 1V on 120V is only .83%, which is a little. The current is the same for the same drop. So 12V systems are very sensitive to voltage drop, making the wiring relatively big, which renders the heating relatively small, at least compared to what the same conductor can carry with higher voltages, at least for runs longer than a pigtail.
- frede
- Location: Washington Sailing Marina, Alexandria VA - 2005 26M 50hp Honda - Kool Breeze
If it is the factory wire (lamp cord) replace it!Wind Chime wrote:We have the factory wire (+/-) running from battery(s) to our panel(s) and the negative is still factory single ground pole behind panel.
