Where can I get a boarding ladder?
Posted: Thu May 05, 2016 11:37 am
by Belle_Chas_SC
I would love to get my hands on a boarding ladder like the one seen on Scott Raines boat?
https://www.facebook.com/groups/8994597 ... 9714488800
Annie
2007
Re: Where can I get a boarding ladder?
Posted: Fri May 06, 2016 1:26 pm
by dlandersson
Not sure I see it?
Posted: Fri May 06, 2016 1:32 pm
dlandersson wrote:Not sure I see it?
This one, I presume?
I just tell folks to park their rumps on the gunwale, grab the bimini with one hand, and swing their legs over and into the boat.
WM has something similar, but with three steps instead of two.
http://www.westmarine.com/buy/west-mari ... 58_001_525
Posted: Fri May 06, 2016 2:16 pm
by C Buchs
Blue Water Yachts has/had one.
http://bwyachts.com/ Looking through their catalog I see "LADDER, BOARDING, BRACKET, LONG" part number 4406-1V0 (this is the bracket that goes on the track), but I don't see the whole ladder. I'd suggest giving them a call. Worst case you should be able to get these brackets and adapt/make a ladder.
Jeff
Posted: Fri May 06, 2016 2:22 pm
I didn't notice that it has track mounts. Pretty nifty. And makes my suggestion moot, as that's not what the OP was asking about.
BWY, I agree, would be the place to call. If it's Mac-related, they probably know about it.
Posted: Sat May 07, 2016 1:53 pm
by Highlander
I,m tinkin thats something u can very easy mod urself just look for a similar 2 step ladder & add 2 one inch rail adapters
easy peasy
Posted: Sat May 07, 2016 2:54 pm
by March
.After one of the members that shall remain unnamed filched the one that was offered kindly by another most generous member, even though I was the first to ask
) I found one locally. I am moderately pleased with it, though it is too high to be of any use when the boat sits on the trailer--and that's when I need it most. When we trailer the boat, the solar panels are stored in the cockpit which makes the aft ladder useless. It is equally useless when we beach the boat and try to leap off the pulpit onto the ground. It's too short. Storing it in the head is also a major pain in the patookus,
The only time I find it useful is to get off the boat and into the dinghy
I think that manufacturing a ladder from two sturdy ropes and wooden / plastic steps would have worked better
Posted: Sun May 08, 2016 6:14 am
by dlandersson
I'm interested in getting one. What is the exact name, source, etc.?
March wrote:.After one of the members that shall remain unnamed filched the one that was offered kindly by another most generous member, even though I was the first to ask
Posted: Sun May 08, 2016 7:14 am
Annie,
For those of us not on Facebook, can you post a non Facebook image?
Posted: Sun May 08, 2016 7:31 am
by March
I don't have it here, but I think it is West Marine. Two steps, stainless steel tubing, with round "crutches"/hooks at the end that may be turned around to make the whole contraption flatter. You can hook it over the gunwales, in the cockpit, and even in the anchor pit in a pinch.
Posted: Sun May 08, 2016 1:28 pm
by Warrior8445
Some time ago, someone had bought or fabricated or had made a SWIM ladder that mounted on the genoa or jib tracks of a 26X. Does anyone remember this or know where to turn for one of these ladders? They were very long, 5 or 6 steps, in order to work with the high freeboard of the 26X.
Thankds,
Rich
Posted: Mon May 09, 2016 9:00 am
by yukonbob
Sorry March I genuinely thought he asked first and by the time I realized my mistake I had offered it to him. The main reason for getting rid of the ladder is that it is another companion way door to contend with. A rather large cumbersome, sometimes wet, sometimes dirty hard hunk of steel that has to be stowed while underway. Other than that it was really nice to have. Also make sure that it will clear your local dock before you shell out money as you may not be able to even use it.
Posted: Tue May 10, 2016 5:41 am
by March
Again, that's nice and generous of you to assume responsibility, but that member (who shall remain unnamed) must have seen my message that I was very interested, posted in plain view right below your offer. So why even make his demand?
It was not like I would change my mind, or we wouldn't agree on the price...
It's the kind of gesture that is no big deal, in the large scheme of things, nor is it "illegal" or "terribly wrong," but merely plain rude.
Like you choose your dock and motor carefully towards it and there's this valiant motorist who cuts in front of you and takes your place
And doesn't even bother to apologize, so proud of his cleverness and his quick maneuvering.
Posted: Tue May 10, 2016 5:55 am
Indeed, the boarding ladder must serve at least two other functions to make it on board Catigale.
Unless its safety equipment, which gets an easement.
We have the two J hook ladder from WM which goes over the gunnel. Only Caitlin has the upper body strength to reliably pull herself up from the water though - I can do it if my life depends on it, but it is not easy.
Posted: Tue May 10, 2016 9:13 am
by yukonbob
I think for lakes and beaching if you could find one that hung off the Genoa tracks like above and hang off the bow for beach loading then it would worth carrying. For us our old docks were much lower and it was ok having it around but everywhere else we went (higher docks) it was a hassle. The other option was right before departing run it up to the truck another PITA. So when they re-did the docks we gave ours away as there was no need anymore. Oh and sailing or powering with it was not an option as it slammed against the hull very easily.
