Page 1 of 3
Mac 25 Restoration
Posted: Thu Feb 04, 2016 3:22 pm
by Sisu
I figured I'd start a thread for the many questions we'll have as our restoration project starts to come together.
First, here's a summary of the story so far:
Back in November, my girlfriend and I went out for a car ride. Driving down a country road we saw a boat by the side of the road with a big "800" stuck to it in blue painter's tape. We turned around. The next day I forked over the cash. I'm no stranger to sailing - I've been coaching racers for almost 10 years and sail scows competitively. I did happen to be looking for a boat but was mainly in the market for a dinghy like a laser or C Scow to race. Nonetheless this looked like a good winter project. The main issues stemmed from a grounding in a storm, which resulted in damage to the keel trunk and a snapped mast. The keel trunk damage was fixed by the prior owner, who also jury-rigged a Catalina mast onto the stub of the broken MacGregor section. A little sketchy but looks like it will work.
We stored it at a friend's house for a few days to replace the wheels and lights on the trailer, then brought it home and pressure washed it
Vacuumed out the interior too
Re: Mac 25 Restoration
Posted: Thu Feb 04, 2016 3:23 pm
by Sisu
Ripped out the godawful electrical system - we'll be rewiring that (minus the questionable shore power rig)
Next we took out all bulkheads and beams and ripped out the headliner
by Sisu
We decided on a good exterior primer covered with a gloss enamel for the ceiling
Next we stripped and re-stained and varnished the trim strips
Then we cut new bulkheads out of Lauan plywood and painted them to match the ceiling
by Sisu
We also decided to replace the windows. Unfortunately the removal took a little gelcoat off. It will be a pain, but we'll have to fix that
That brings us to yesterday, which saw the arrival of our new tiller, windows, and some nice Lewmar #6 winches I found cheap on eBay. I plan to move the factory ones to the cabintop.
As questions come up I'll post them here. Looking forward to sailing this spring!
Posted: Thu Feb 04, 2016 4:25 pm
by cptron
Good luck and keep us updated with pictures cause they tell a lot. :D Looks good so far and remember new guy buys the pizza. Some like anchovies however since I beat him to it you can leave them off. :P
Posted: Fri Feb 05, 2016 8:31 am
by Freedom77
$800 is a steal. another $20,000 and you'll be ready to launch :) Where did you order the tiller? I have found Rustoleum white high gloss oil base is excellent for interior. Welcome to the legion of the Damned :evil: Keep us posted. Fair Winds and Full Sails...Old Salt
Posted: Fri Feb 05, 2016 10:20 am
by Sisu
Freedom77 wrote:$800 is a steal. another $20,000 and you'll be ready to launch :) Where did you order the tiller? I have found Rustoleum white high gloss oil base is excellent for interior. Welcome to the legion of the Damned :evil: Keep us posted. Fair Winds and Full Sails...Old Salt
Windows and tiller are ruddercraft. Thought about doing our own tiller but for $99 unfinished it's a good investment that saved us a lot of time. Very professional job on both the tiller and windows, we're impressed!
We do have some pretty heavy damage to the rudder. Does anyone here have experience building their own?
(by the way, the $800 included sails, trailer, and outboard! We don't have any illusions on saving money, but this way we get to rebuild it to our liking and it's a fun project!)
Posted: Fri Feb 05, 2016 1:54 pm
by THE CUSCUS
Looking good!! The Mac 25 is a great boat. Enjoy, and keep posting your progress.
Posted: Fri Feb 05, 2016 3:13 pm
by grady
I would repair the rudder rather than fixing it. If fixing it is not an option Ruddercraft does make a good replacement. It would be fun to make one but in the end a one off is not going to be any less expensive. Unless you are looking to make a better performing rudder.
Posted: Fri Feb 05, 2016 3:41 pm
by Sisu
grady wrote:I would repair the rudder rather than fixing it. If fixing it is not an option Ruddercraft does make a good replacement. It would be fun to make one but in the end a one off is not going to be any less expensive. Unless you are looking to make a better performing rudder.
Well, an actual NACA section might be nice. I do know a guy who has a CNC router used to make wooden aircraft parts, so that might be an option. The existing rudder is ripped open at the bottom and badly de-laminated around the damage (probably from the grounding that damaged the keel trunk). Maybe for this season we can do some fiberglassing and call it good.
@THE CUSCUS, I know you've done a lot of rigging work - do you recommend relocating the leads for the working jib at all? I am considering installing tracks if I can find some cheap ones, otherwise I'll replace the plastic fairleads and move them if necessary.
Posted: Sat Feb 06, 2016 8:08 am
by THE CUSCUS
I can't comment on those fairleads, as I have never used them. I removed them. I have the older style 25 with the nice side decks and have 1" tracks up to the chain plates. I don't use my working jib very often, and when I do it works fine using the cars on the track . I would definitely get some track put on. In the general scheme of boating expenses, the track is not that expensive.
https://m.youtube.com/watch?v=iY8IwdjN0WI
Posted: Sun Feb 07, 2016 6:40 am
by 81venture
Before you order more "bits" check with me..
I am sitting on a pile of stuff
dave
Posted: Mon Feb 08, 2016 10:17 am
by Sisu
Dave, PM sent
THE CUSCUS, you really sheet the jib that far outboard? I was thinking if anything the leads need to come inboard a little, but I guess we won't know until we're sailing. I'm jealous, by the way - I think the Venture has a much better deck setup. The lifelines strung across the cabintop on the Mac look goofy.
Here's a shot of the weekend's progress - Bulkheads are re-mounted along with the trim strips. The bulkheads were a bear to re-fit and actually they are suspending the mast support a few millimeters off the base (which has an indentation from years of use - may have to replace the core under it at some point)! We'll have to shim that.
Posted: Mon Feb 08, 2016 10:43 am
by Freedom77
Sisu: LOOKS GREAT! I built a rudder out of teak. $$$$$. A lot of the stock Mac rudders were fiberglass over foam which tended to swell and crack. Ruddercraft builds an excellent product. Also check with Blue Water Yachts in Seattle. The specialize in Mac/Venture stuff. What did you use for interior paint? Also, check between mast step and keel trunk sometimes under mast post there is a gap which has to be shimmed up or the deck will pump and your mast might buckle. Not a good day at sea. :P Welcome to the Legion of the Damned! Keep us posted. Fair Winds and Full Sails...Old Salt.
Posted: Mon Feb 08, 2016 1:39 pm
by THE CUSCUS
Sisu, your boat is looking good there. I do agree the Ventures had many good features. The ones towards the end on their run, especially. Mine is a 1979. I know having the jib track closer to centerline will allow you to point alittle better when using the jib as compared to having the track outboard, but when I'm racing I'm not using the jib :wink:
Add your location to your profile so we all can see where you are from.
