Man Cave
Posted: Thu Nov 05, 2015 4:49 pm
by jrcanoe
I like having my 19 in the back yard. While boating this past summer I spent almost no time below. Now that it is in the back yard I have taken a nap, surfed the web, listen to tunes and read. I found a 600 watt ceramic heater that will work with my 750 watt inverter. It hasn't been cold enough to really test but I had to shut it off after about 5 mins when it was 45 out. With my 2 batteries I think I can get about 2 hours run time on the heater. I put the boat in at a dock right after I bought it so didn't get any mods or repairs done. I have a kicker bracket to mount, radio to put in and need to repaint the bottom.
Re: Man Cave
Posted: Thu Nov 05, 2015 4:55 pm
by Norca
I love having the boat in the back yard as well
Today I installed a flexible water tank under the aft berth, not done yet so I can spend some time
tomorrow with the wiring.It's funny how a 2 hour job can take all day
I also have a job on the brakes and bearings when the weather is nice.
Re: Man Cave
Posted: Thu Nov 05, 2015 5:19 pm
jrcanoe wrote:I like having my 19 in the back yard. While boating this past summer I spent almost no time below. Now that it is in the back yard I have taken a nap, surfed the web, listen to tunes and read. I found a 600 watt ceramic heater that will work with my 750 watt inverter. It hasn't been cold enough to really test but I had to shut it off after about 5 mins when it was 45 out. With my 2 batteries I think I can get about 2 hours run time on the heater. I put the boat in at a dock right after I bought it so didn't get any mods or repairs done. I have a kicker bracket to mount, radio to put in and need to repaint the bottom.
Man cave. grunt grunt
Why don't you just plug the heater into an extension cord? 600 watts into 12v is 50 amps at 100% efficiency. I bet after 5 minutes your batteries were dead. Check their level.
Re: Man Cave
Posted: Thu Nov 05, 2015 5:36 pm
by Lee Ward
Guilty.
Re: Man Cave
Posted: Thu Nov 05, 2015 5:56 pm
by jrcanoe
I do have an extension cord run to the boat and will use it in the yard and shore power at the dock. But I can use the inverter and heater at anchor.
Re: Man Cave
Posted: Thu Nov 05, 2015 8:37 pm
I think if you do the math, you will see inverter and any heat device will only run for a few minutes before killing the batteries. 12v batteries just don't hold that much energy.
For heat, I have a small Mr. Heater runs on 1lb propane bottles. Only used it once, but it heats very well. Nothing produces heat better than fossil fuels.
Re: Man Cave
Posted: Thu Nov 05, 2015 10:27 pm
by yukonbob
I second this.
Re: Man Cave
Posted: Thu Nov 05, 2015 11:00 pm
by Max Entropy
Mine's docked in the back yard winters, but have to retrieve from the anchorage in Tsehum Harbour next week so can relax and not worry about storms. It does make a nice man cave, but, oh, do I have to clean the hull, before starting on the drydock season upgrades! Still, there's always skiing to while away the worst of the cold before the zephyrs of Spring wile us back to the sparkling waves.
Re: Man Cave
Posted: Fri Nov 06, 2015 1:07 am
by Highlander
Boats in the drive way waiting to get into her shop where I can work on her interior all winter if I wish
fireplace & all
http://vid844.photobucket.com/albums/ab ... hfpmpa.mp4
Re: Man Cave
Posted: Fri Nov 06, 2015 2:01 am
by dlandersson
I'm jealous - I would love to be able to do that.
Re: Man Cave
Posted: Fri Nov 06, 2015 10:12 am
by ecossebob
Hi Highlander love your fire place heater. What it's name and where did you get it?.
Thanks Bob.
Re: Man Cave
Posted: Sun Nov 22, 2015 10:08 pm
by Neo
OMG ... So good reading this ... And I thought I was the only one
So far I've spent far more time on dry dock (home lol!) than on the water! ... Just love optimizing the single handed setup and pack-up ... have got it down to 40mins
All the best
Neo
