Purpose Of Hole
Posted: Wed Mar 18, 2015 3:34 pm
by macsailor65
I am getting ready to put my 2006 Mac M in the water for the first time. Before I do I would like to know what the purpose of the small holes are above the rudder brackets.
Do any of you know? Also I am trying to post a picture of it. Can you tell me what I did wrong?
Thanks for your help,
Bob
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 4:34 pm
by Gabby_SC
without picture, I'm guessing that you are referring to the hole that would be used for transporting the boat by trailer (when rudder is lifted, it should have a pin or bolt to secure the rudder from falling down and striking the pavement)
http://www.ruddercraft.com/catalog/prod ... cts_id=116
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 4:50 pm
by Highlander
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 4:57 pm
by Sea Shadow
macsailor65 wrote:I am getting ready to put my 2006 Mac M in the water for the first time. Before I do I would like to know what the purpose of the small holes are above the rudder brackets.
Bob
If you are referring to the small holes on the transom just above the rudder mounts, these would be drain holes for the steering system.
Michael
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 5:09 pm
Yea, I think you are referring to what folks above are describing as drain holes for rudder shafts.
I wondered also.
Like this one.
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 7:52 pm
by Highlander
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 8:07 pm
by Ixneigh
Depends on where the hole is located...
But yea, rudder system drain.
Don't plug it up. Water will accumulate in the back area of the boat. Oh wait. it does anyway. More water will accumulate...
Ix
Re: Purpose Of Hole
Posted: Wed Mar 18, 2015 8:19 pm
by Gypsea Wind
I was investigating these holes a short while ago. What I found was that there is a void space above where the rudder post enters from the outside and below where the rudder post exits into the rear berth area on the inside. This space seems to be a couple to few inches high with the rudder post running through. The hole is located at the bottom of the space and serves as a drain for any water that gets in around the rudder post.
Re: Purpose Of Hole
Posted: Thu Mar 19, 2015 8:19 am
by macsailor65
Thank you all for your comments. I appreciate your help. Can anyone tell me how to post a picture.
Bob
Re: Purpose Of Hole
Posted: Thu Mar 19, 2015 8:31 am
Upload your picture from your computer to a pic hosting site.
http://www.tinypic.com doesn't require an account or any information at all, personal or otherwise, but you also can't maintain a library. Other sites like photobucket.com require a free account, and you can manage your pics any time after you upload them.
Using tinypic as an example, upload your pic off your computer, and watch the short commercial and answer the security question (if asked - the site doesn't always ask), then copy the link with the ubb code on each end (img and /img at the ends) by left clicking to highlight it, then right clicking and picking 'copy' (or ctl-c on your keyboard) in its entirety, and just paste it into your post (right click and 'paste', or ctl-v). Hit 'preview' to see if it looks ok before finishing the post. Put a blank line before and after that link for best appearance.
That's it. Easy peasy.
Click 'quote' in this post to see what the url with ubb code looks like, uploaded to photobucket, but the format will be the same for any such site.
Re: Purpose Of Hole
Posted: Thu Mar 19, 2015 10:40 pm
by Mac26Mpaul
Yes they are rudder dam drain holes and if you plan on using your boat as a beach house like I do, it is a good idea to have some small plugs just in case you mess up like I did here:
http://www.macgregorsailors.com/forum/v ... 7&start=15
Re: Purpose Of Hole
Posted: Fri Mar 20, 2015 3:04 am
by Cougar
Why am I not authorized to view that topic?
Re: Purpose Of Hole
Posted: Fri Mar 20, 2015 5:06 am
by aviro
Me to
Re: Purpose Of Hole
Posted: Fri Mar 20, 2015 5:07 am
by aviro
Not authorized
Re: Purpose Of Hole
Posted: Fri Apr 03, 2015 1:26 pm
by macsailor65
Thank all of you for your post. I believe it is a vent hole and pictures sent to me show that other M's have the same holes.
Bob Williams
