Keel cable bolt question.
Posted: Mon Jan 05, 2015 3:22 pm
I'm rehabbing a V17. It is ready for paint but I'm waiting for warmer weather. In the mean time I'm working on other problems.
Im replacing the bolt that supporrts the keel cable as it passes through the keel valve, it has a grove worn half way through it from the friction of the keel cable.
It was a 3/4" bolt and when I tried to screw the nut off booth the nut and the bolt head twisted off leaving the bolt shank still in the keel valve. I've tried to remove the bolt but it is either coroaded in place or it is actually screwed into one side of the keel valve. Bottom line is it's not coming out, yet...
Have any of your ran in to this problem? Any suggestions?
Can anyone tell me if the keel valve is made of steel and encased in fiberglass and epoxy?
Last question, am I using the correct name for this part of the boat that the cable passes through, keel valve?
Thanks for any and all input.
