26M Aluminium Trailer wheel bearings
Posted: Tue Oct 01, 2013 9:40 pm
by DaveJock26M
Does any one know the brand or model number for the bearings used on the macGregor factory issued aluminium trailer?
I am planning to tow the Mac 26M approx 2500 klms and I want to buy a spare set of bearings locally in Australia.
Thanks & Regards
Dave Jock
Re: 26M Aluminium Trailer wheel bearings
Posted: Tue Oct 01, 2013 10:53 pm
by mastreb
The brand is:
http://www.ufpnet.com/
You can dig through their site to find the replacement bearing information.
But don't worry. The bearings aren't going to need replacement in a mere 2500km. I just pulled a three year old stock trailer 13,200km with no bearing issues. Just grease them as per the instructions on the site and they'll be fine.
Matt
Posted: Wed Oct 02, 2013 8:14 am
If it helps, I contacted a UFP dealer here in the states (Six Roblees) and provided them a serial number Axle ser# A427504 (Thanks Highlander) and they looked it up for me to buy another axle.
I agree with Matt, check the grease and they should last a long time. Factory installed bearing buddy fittings to hold grease.
Posted: Sat Oct 05, 2013 2:00 pm
Dave - very prudent to carry spares. The Mac bearings are run at about 90% of their rated capacity and will go from good to junk in the course of about 50 miles, if they run dry or get dirty.If they are kept lubricated and adjusted, they run a long time, though.
Posted: Sat Oct 12, 2013 12:53 pm
by sirlandsalot
nothing wrong with carrying a few extra bearings with you either, they are cheap, and when you need them you really need them.
Posted: Wed Oct 16, 2013 11:44 pm
by DaveJock26M
Thanks for your input re bearings.
Much Oblige
DaveJ
Posted: Sun Oct 27, 2013 6:13 pm
by DaveJock26M
Hi All,
Made the 2700 klms trip no problems at all! boat towed like a dream.
Thanks for the inputs.
Dave J
Posted: Sun May 18, 2014 9:56 pm
by nkosi
Nkosi, New on deck guys HI!! DJ. just replacing brgs on my 2007 M26 alum trlr.paralell shaft,Timken Set 13 L68110 - L68149. ( BO25829807)
WWW.timken.com.marine shaft seal by Seagull P6692. Y1,678x2328x0.591, NBR. Im using Penrite marine grease,NLGI 2 Product code MARGR00045.LITHIUM COMPLEX. Bar Code 9 316517005126 (colour GREEN)Operating Temp range -15 deg C to +170deg C.drop point275deg C.
www.penriteoil.com.au I hope this helps ,will be watching this site for more helpful info & boat mods.
Posted: Thu May 22, 2014 2:50 am
Welcome on board Nkosi!!
Bring pizza for the group! (forum tradition)
Think about updating your profile with boat and location so we know a bit more about you.
