Cockpit floor weight limit
Posted: Fri Jun 07, 2013 11:38 am
by grnwtrcruzn
Hi all,
I've been through all the info I could find about the weight limit on the
cockpit floor but haven't been able to find anything so I thought I'd turn to the experts
. I'm planning on heading out with a couple of buddies next weekend who are on the larger size one's 6'2" and about 225 lbs the other is 6'6" and ~400lbs and then there's me at 160lbs. So all together where close to 800lbs. This got me thinking about what kind of weight that cockpit floor might be able to hold. Anyone have any thoughts on this?
Re: Cockpit floor weight limit
Posted: Fri Jun 07, 2013 11:43 am
by JohnCFI
I'm about 230Lbs, and the floor holds me up OK. I would have thought you would be fine....
Posted: Fri Jun 07, 2013 11:51 am
by grnwtrcruzn
JohnCFI wrote:I'm about 230Lbs, and the floor holds me up OK. I would have thought you would be fine....
That's good to hear! Thanks for the reply
Posted: Fri Jun 07, 2013 12:46 pm
I would think the cockpit will be fine. However, that's a lot of weight and you will need to balance everyone. Good counterweight in a heavy wind, just be fast to move during tacks.
Posted: Fri Jun 07, 2013 3:17 pm
by Paulieb
I am 6' 4" 370Lbs - never had any issues...
I've had my Mac for 5 years.
Paiulieb
Posted: Fri Jun 07, 2013 4:42 pm
by mastreb
I'm 6'5", 260 lbs., and I've got sailing with a guy whose 420 lbs., as well as 1500 lbs. of human ballast total (more than anyone should). There's nothing to worry about in terms of structural integrity, but I wouldn't let those big guys go topside and grab the mast on a serious heel.
Matt
Posted: Fri Jun 07, 2013 6:06 pm
If the boat is designed to hold six adults, which it is, then you should not have any problems with three Titans. With the weight that is.
Fitting comfortably might be an insurmountable challenge
Posted: Fri Jun 07, 2013 6:35 pm
Wow, we have some big sailors here. Lucky for me I don't have to reveal my 5'-11" and 225 lb stature. Phew!
Re:
Posted: Fri Jun 07, 2013 6:52 pm
by grnwtrcruzn
NiceAft wrote:If the boat is designed to hold six adults, which it is, then you should not have any problems with three Titans. With the weight that is.
We'll just need to add a couple of 100 lbs ladies to help balance the load and make the cramped conditions more bearable
Posted: Sat Jun 08, 2013 9:17 am
I resemble that remark....
Posted: Sat Jun 08, 2013 2:04 pm
by JohnCFI
I'm just short for my weight!
Posted: Sun Jun 16, 2013 12:29 pm
by Gazmn
When I have >4 aboard, or roughly >650 lbs, I keep the water ballest in even, when not sailing.
I think there is a factory recommendation also to that effect.
Posted: Sun Jun 16, 2013 1:38 pm
by mastreb
I also forbid transiting to the bow topside if we've got more than 4 people aboard. Down through the cabin and up through the hatch if you want to go forward. That's also our rule for anyone under 14. Only person who gets to pull the boat over in an emergency is me.
Matt
Posted: Fri Jun 21, 2013 6:59 pm
by grnwtrcruzn
... so it went off without a hitch. 4 of us total pushing a bit over 1k lbs
cruising around for a day. I was amazed at how the
handled.... the same; the boat always surprises me
Posted: Fri Jun 21, 2013 7:32 pm
by Johnacuda
Wow, I'm 5' 4" and 160. Single-handing, I am starting to understand some of the variables that help my BF50 pop my
up on a plane so easily.
