Page 1 of 3
Mantus Anchors
Posted: Tue Feb 26, 2013 9:21 am
by Obelix
Just received my new 25lb Mantus anchor and was impressed by their packaging in a wooden box.
Being able to break it down solves the storage issues we have with new generation anchors on the
The Mantus is going to be used on grassy or otherwise difficult bottoms to complement the Fortress I use for sand and mud.
Obelix
Re: Mantus Anchors
Posted: Tue Feb 26, 2013 9:27 am
by Tomfoolery
Not to divert from this brand of fun, but what size Fortress are you using, and how do you like it?
Re: Mantus Anchors
Posted: Tue Feb 26, 2013 9:34 am
by Obelix
I use the F11 and it works well so far. Fortress has the clear weight advantage over other Danforth types.
Obelix
Re: Mantus Anchors
Posted: Tue Feb 26, 2013 9:58 am
by Tomfoolery
Thanks. I've used primarily Danforth (and knock-offs) and Bruce (also Claw, a knock-off) types, but only in mud and sand. I've never had to anchor in heavy weeds, but that may change as I start poking about in different sailing areas, far from home. Which is half the reason I got this boat.
Be sure to give us the play-by-play when you put the new one to work.
Re: Mantus Anchors
Posted: Tue Feb 26, 2013 10:31 am
As with any ground tackle, make sure those bolts are locked tight.
Re: Mantus Anchors
Posted: Tue Feb 26, 2013 12:43 pm
by Uncle Jim
I received my 35# mantus just before Sandy struck. The folks over at sailnet had a big thread on it. there are a couple of well informed members who did some test and foud it to be great in holding in all types of bottom conditions. Can't wait to try it out.
Re: Mantus Anchors
Posted: Tue Feb 26, 2013 1:24 pm
by Obelix
Uncle Jim,
I talked with the designer at the Miami Boat Show and he figured the 13lb may be enough for the Mac but recommended the 25lb to have a significant safety margin.
Obelix
Re: Mantus Anchors
Posted: Wed Feb 27, 2013 9:22 am
by Uncle Jim
Obelix wrote:Uncle Jim,
Obelix
I sold my Mac X last year am now driving a Hunter 34'. Thought about going up to a 45# but I'd have to haul it in
Re: Mantus Anchors
Posted: Wed Feb 27, 2013 10:33 am
by Paul S
Uncle Jim wrote:Obelix wrote:Uncle Jim,
Obelix
we have a 35# CQR on our 38 Ohlson. works quite well and is easy enough to haul it in.
The FX11 works quite well, and fits in the M locker. sets, but doesn't reset well in weeds. I bought a small delta plow for weeds for the Mac. That worked like a charm. light and easy to store.
The lastest practical sailor testing is giving a lot of kudos to the Spade anchor's ability to set quickly and, more importantly, reset the fastest when the wind/current changes.
Any case, the anchor is only as good as the captain who sets it! A good anchor set with poor scope or incorrect bottom for the anchor won't hold in a good blow...or when the wind changes at 3am
Been there..done that!
Re: Mantus Anchors
Posted: Wed Feb 27, 2013 10:50 am
I had a 22# Bruce on my Hunter 34. Worked great. Easy to retrieve and set. Like it so much so I bought one for my Mac. At 22lbs it's probably overkill, but the 16lb seemed too small.
Also had a Danforth HT but rarely used it. The Bruce fits nicely on the roller.
Re: Mantus Anchors
Posted: Wed Feb 27, 2013 2:49 pm
by Boblee
Don't even think about carrying a Danforth type anchor now IMHO they are just not reliable even in sand, use a Sarca and a Rocna which look similar to your Mantus but think the bolt together bit would put me off, just another weak point.
Re: Mantus Anchors
Posted: Wed Feb 27, 2013 4:12 pm
by Obelix
Boblee,
There are 4 bolts; each of them has enough breaking strenght to lift the
free of the water, with lots of safety margin to spare, if the deck hardware would not be ripped out in the lift.
No worries
Obelix
Re: Mantus Anchors
Posted: Wed Feb 27, 2013 5:09 pm
by Uncle Jim
what year was your 34? any suggestions on redoing the keel?
Re: Mantus Anchors
Posted: Thu Feb 28, 2013 9:09 am
by Tomfoolery
Here's a 4-1/2 minute 'commercial' youtube video of the Mantus.
http://www.youtube.com/watch?v=BCEBOOnDcOU
And another of the similar Rocna.
http://www.youtube.com/watch?v=bhjdlKwTdv8
Bear in mind that these folks are selling these products, so take them with a grain of salt (sand?). I have no connection to any of them, and have never even used either style anchor. (I don't want to get Mod-smacked.
) But watching these vids is an interesting way to spend a few minutes in the middle of winter. Beats shoveling the driveway, which I'm putting off.
But I digress . . .
I've only used Danforth and Bruce types, plus a couple of others very small ones for lunch hooks.
In fact, I too had a relatively puny looking 22 lb Bruce on my Hunter 340 (12,000 lb loaded), and it set and held like mad in Lake Ontario. I'd use a smaller Bruce on my
, but the locker is too small for that shape I believe, and I don't have a bow roller. But the Danforth seems to work well for that bottom, and I have an 'oversized' one below for emergencies.
But if I was going to spend the money on another anchor, and had a way to store it ready to deploy, I'd probably give the Mantus or Rocna a try, too.
Re: Mantus Anchors
Posted: Thu Feb 28, 2013 9:51 am
Uncle Jim wrote:what year was your 34? any suggestions on redoing the keel?
It was an '84. Had the yard scrape it down an epoxy coat it once.
