Winter Project
Posted: Sat Jan 26, 2013 3:36 pm
Ok so after a year of the boat sitting in the hanger and not moving I finally started my winter boat project to get her up and running for the spring. It felt good to work on her all day. This is the list of items for this winter (probably making up for not doing a winter project last year)
2 D31M Optima batteries mounted in the bow. previous batteries were in the laz and with a 9.9 yamaha 4 stroke it made the boat stern heavy. This should help balance her out. Today I was able to run the battery wire from the stern to the bow. I have the battery hold downs ready to bond down, will wait until the batteries show up this week. Two 100A current limiters located at the batteries and an battery combiner.
Had a gate project this year at the house ended up with a 20W 24 volt solar panel that I did not need. Converted it to 12V and will install on the stern rails over the engine.
New compass installed today and wires run for lighting.
I got a good deal on two block for a boom vang from Defender $50 for one and $30 for the other one. (check out the clearance section) Once the got here I realized they were better than my main sheet blocks, so main sheet blocks up to the boom vang and new blocks on the main sheet.
Ordered Boom Kicker today. I have been sailing on a Sonar 23 and a MacGreggor 26D with one. Did not realize how nice it is to drop the main and not have the boom fall into the cockpit.
Getting ready to order new sails. Full roach main (will have to put lift on backstay). New Asym spinnaker to fit my 2ft bow sprit and block above head stay. With the measurements I gave the sail maker spin will be 505 sq feet. Should be great performance but I am sure I will be putting it away somewhere around white caps.
Think I got a good line on a used 150 genny.
Still looking for a good 110% deck sweeper.
Will be buffing out the Bottom VC performance epoxy with 600 grit.
After all this hope I still have money left over to take her out
Had a good year off dong some major projects on the house and racing on friends boats, but feels really good to be getting her ready for the spring. Cant Wait!
