Replacement winch/upgrade swing keel for 2-22?
Posted: Sun Jan 20, 2013 2:10 pm
by mknll
Hello:
My relative recently purchased a 1976 Venture 2-22 that needs to be completely overhauled. He is looking for a replacement winch or an upgrade for the swing keel.
I have no knowledge of MacGregor sailboats. Could anyone point me in the right direction to find these parts?
Thank you.
Re: Replacement winch/upgrade swing keel for 2-22?
Posted: Sun Jan 20, 2013 6:34 pm
by Bob McLellan
Look at Northern Tool on line, The winches are called a BRAKE WINCH, not the same as a trailer winch. You'll also need about 11 or 12 feet of new stainless cable and the ferrules and a tool for the ferrule if you do the job yourself. West Marine can also do cable work.
Posted: Mon Jan 21, 2013 5:56 pm
by mknll
Thanks! I appreciate it.
Posted: Mon Mar 04, 2013 9:40 am
by Tsatzsue
Make sure you note the way the drum winds. There are CCW and CW rotations. I upgraded to the heavier winch and found out the hard way.
Posted: Mon Mar 04, 2013 3:56 pm
by DanInCanton
Blue Water Yachts specializes in MacGregor parts for all models. I've bought a few items from them and they are tremendously knowledgeable about all the boats. You can look them up at http://bwyachts.com/
Best Wishes,
Dan
sailorguides.com
Posted: Wed Mar 13, 2013 4:17 am
by chipveres
Following up on what Mr. McLellan said, when I bought a new winch at Northern Tool, the handle wouldn't fit the boat. I wound up (bad pun) using the new winch with the old handle. So save the old stuff in case you need to swipe parts.
Chip
Posted: Sun May 18, 2014 11:43 pm
by Little_Shenandoah
http://bwyachts.com/BWYParts/info.htm
I haven't called Blue Water Yachts yet, but I'm not interested in drilling new holes if I don't have to. Has anyone used the keel winch w/handle that Blue Water sells in order to replace their rusted out winch? If so, I would love to see some picture and get some measurements. Namely... what is the exact distance between the mounting screws on the new winch?
Posted: Mon May 19, 2014 4:41 am
by Ixneigh
My 73 had a standard trailer winch. That worked but you had to be really careful with it. I don't think it was original but I replaced it with another when it rusted. I wonder if the winch the M model boat uses for the mast raising set up would work?
Ix
