Questions about Mac25 swing keel
Posted: Sun Aug 05, 2012 7:00 pm
On a recent trip my Mac25 was in a slip which was exposed to heavy boat traffic. I mistakenly left the keel down and the constant wake rocked the boat violently and the keel was knocking pretty hard. This led to some pretty major leaking from the keel bolt opening itself.
The keel bolt area leaked when I first got the boat. I pulled off the washers and noticed that the bolt hole in the fiberglass truck was ovalized from wear. I filled it with epoxy putty and re-installed the washer. This seemed to work good and I had a dry bilge for several trips out. But the violent motion back and forth at the exposed dock broke up the epoxy and caused the leaking. I did a temporary fix using a "never hardens" roof repair product that I found at a hardware store, and neoprene washers. The repair worked pretty good for the rest of trip with no leaking. But I don't want a repeat of the incident so I would like to find a more bomb proof solution.
My other major concern is of the knocking itself. It seems like the keep moves side to side more than it should. I know this is a common issue with swing keels but I would like to eliminate it as much as possible.
My main thought is to drill out the both the fiberglass trunk and cast steel keel to accept a larger bolt. It currently has a 5/8 bolt so sizing up to 7/8" or 1" would likely get me past the deformity and I would have a tighter fit which could solve both problems.
Dose anyone see any major negatives with this idea.
I am open to any other ideas as well. Any feedback would be appreciated.
Thanks
Gene
Lake Isabella, CA
Mac 25; Hobie 18
Thanks
Gene
Lake Isabella, CA
Mac 25; Hobie 18
