I recently asked a question in another thread about the use of flexible stainless steel wire but there were no takers.
Given the continuing stories of forestay failure, it seems to me to be a really important idea, so I thought I'd ask again in a new topic.
I'm talking about 7:19 s.s. wire which is made up of 7 groups of 19 small strands. I was told it is much the same strength as the usual 1:19 but is much more flexible - it is designed to be used in machinery pulleys etc - so it can go round corners and bends and can presumably withstand side stresses much better than the regular stuff.
Wouldn't this be ideal for use as a forestay on a Mac? Are there any downsides to its use?
If it is as good as it seems, then surely it is a MUST have?
Look forward to hearing any thoughts on this.
Regards
Mike
What's the best wire to use for the forestay?
Re: What's the best wire to use for the forestay?
The issues to be understood are:
Tensile strength...easily documented, probably not a problem
Corrosion resistance to salt water environment
Swage strength and method
Fatigue resistance...the big one IMHO
Cost and availability
Tensile strength: As I understand it, the strength is much the same as the ordinary stuff. Maybe a little less, in which case go up a size?
Swage strength: Agreed - make sure your rigger does a good job of swaging.
Cost and availability: The flexible stuff seems to be generally available from chandleries - their advertising suggests they expect it would be used for running rigging on boats but that's not to say it can't be used for standing rigging. Cost is a bit more than the ordinary wire but not much more.
Corrosion resistance: Good point! Is it better or worse or the same? (If it is used in running rigging on boats then presumably it is OK?)
Fatigue resistance: Yes this is the "big one". Could this be an important improvement? Or not??
Mike
Mike
- Sumner
I did a couple google searches on it the other day when you posted and it seems to now mostly be used for people rigging older boats that want them restored more original if I remember right, or a new boat that they want to appear to be older.
There must be a reason now why 1X19 is almost universally the standard to use vs. the older standard of the 7X19.
If you read this thread and the guy is right....
http://forums.hunter.sailboatowners.com ... hp?t=76518
....the 7X19 stretches more and that could result in problems. I wouldn't use it myself. The 1X19 is probably on hundreds of thousands of boats for a reason. Good luck,
Sum
Our Endeavour 37
Our MacGregor S Pages
Mac-Venture Links
Sum
Our Endeavour 37
Mac-Venture Links
....ahhhhhh, the perils of the Internet........If you read this thread and the guy is right....
- Sumner
ExactlyCatigale wrote:....ahhhhhh, the perils of the Internet........If you read this thread and the guy is right....
Sum
Our Endeavour 37
Mac-Venture Links
